Clean a small shark. (Dead critter content)
Shark as a survival food? For sure. Small sharks feed in very shallow water. While fishing yesterday I saw no less than a dozen in water one to two feet deep. Some even hitting the shore. While illegal here now to spear or net them, in a survival situation they would be fairly easy to gig, or run into an improvised net. All sort of netting washes ashore, and you can use the inside strands of 550 cord to construct one also. Just about any dead animal you find on the beach can be used to chum them into coming close to the shore, and as bait. Guts and other parts of fish can be used as bait. I've caught 18 in the last two days on a break down 4 ft. rod with 10 lb. test. Of course you need a leader of some sorts. I can only keep one a day, so here he is. First thing I do is cut him from the throat down past the anus, remove the guts, and let him bleed out. I did this as soon as I caught him, and brought him back to the camp to clean. Gut them as soon as possible, it will help bleed the meat clean.
Today I am using my BRKT Kephart and trusty Skeletool.
Then I make slits behind the head, and on each side behind the gills. And remove the dorsal fin.
Then I make a slit along the back, the length of the fish. Grab the skin and pull. Just like the frogs and catfish, the skin will pull off in one piece.
Now some folks, especially with larger sharks, skip the skinning and go right to this part. Remove the head, cut down behind the gills. Then, cut across and through the the shark, creating nice steaks.
Anther way is to simply fillet the meat off the single "backbone."
Without a bunch of bones in sharks, there is a pretty nice bit of good meat. Here is what is between the head and tail. Notice the single length of vertebras.
Since I am going to cook "sharks bites", I cubed all of it into small cubes. I trim any dark meat. Some don't, but I find it give the meat a cleaner taste, and doesn't distract from the sweet flavor these little blacktips have.
I'll try to remember to post some preparing and cooking pics this time. I can't convey how delicious these things are. Fried, blackened, grilled, so many ways to prepare them.
One problem with cleaning all these fish, frogs and such in one place is it attracts other animals. This gator is coming up every time he sees me walk out on my dock to clean something, and has been the last couple of weeks.
I showed him my Kephart, and told him he was next, but it didn't seem to impress him.
Great Post FishShooter! Your how-to posts are a real asset to the forum. The pics are simple and clear and I'm sure that your instructions will give some forumites who have not done this the confidence to give it a try.
I love shark fishing and find the little guys like that to be the best eating. Should also not that its particularly important to remove the bladder quickly because if it ruptures it can spoil the meat. Obviously that wouldn't happen if you remove all the innards like you did but I figured it was worth a mention.
i had some shark once and for some reason it had a slight sour taste to it. it was fresh so the meat was good. do smaller sharks have a better taste than larger ones? (and no it wasnt a "lemon" shark :D)
Good information to know! Thanks for the tutorial, never seen a Shark cleaned before. Appreciate the post :thumbup:
Thanks Md! :thumbup: You're right! Probably the most important thing is to get those innards out as quickly as you can. Not only can the bladder bust, but I've heard leaving all that stuff in there can cause the blood to breakdown into an urea like substance.
Smaller ones are much, much better. Also, the different types taste much different. Some aren't worth eating, unless your hungry! In a survival situation I'll take what I can get. Fishing to take one home? Smaller Blacktip: excellent table fare. These taste sweet, most folks that try it says it has a scallop taste to it. The consistency is meaty, and tender.
There was probably some light contamination from not removing the bladder fast enough. With heavy bladder contamination the meat is sour and bitter and completely inedible. Young sharks of most species usually have a sweeter and milder taste than older sharks of the same species. The taste of sharks is heavily dependent on their diet as well. I have tried sand-tiger on two occasions and found it to be very "fishy" with an oily meat. The liver and bladder was removed quickly so there was no contamination. On the other hand, lemon sharks can have a mild taste even if seven feet when caught. I wonder if that is due to the heavily crustacean diet? I think that the easiest sharks to catch around here (Maryland) would be the spiny dogfish. It has an acceptable flavor but they only get about 3.5-4 ft long so the young ones are very small and usually not worth keeping. By the way, anyone interested in trying shark should also have a go at skate. The dish "Bay Scallops" is actually round cookie cutter shaped pieces of skate wing. The older animals can have quite a bit of the fishiness removed from their meat by soaking the steaks in milk over night in the fridge.
Yum looks good. Thanks for sharing.
Edit: Had a question. Two really. First how do you like that leatherman? Second, what's the etiquite in cleaning fish in public areas? I would think it's fround upon.
+1 :thumbup: Your tutorials are excellent!
I really like the Skeletool. I have a Charge, but it so heavy. I can get the same tool set with a Skeletool paired with a Farmer. And if I lose one, I still have the other. The plier shape is great for removing hooks, rigging tackle, as as you see, pulling the skin of stuff. I carry the Skeletool with a BRKT Necker. That and a Farmer in the pocket covers a lot of bases.
I usually have them in my cargo pocket. But when in saltwater, I just have this on me, as I don't have to worry about rust.
As to cleaning fish in public, I go out of my way to avoid other people. Here is a pic I took with my phone of my buddy while we were fishing Sunday. It's public property, but you have to have a permit and a 4X4 to get there. I see folks back there time to time, but everyone can have a mile or two of beach to themselves most the time.
Same area a few weeks ago.
Great place to get away and camp for a few days.
Down the beach you run into houses, but still pretty spread out. I see folks cleaning their catch right there. It's bad form to do it if there are other families close by. Some of the boat landings have dedicated cleaning stations, and place to either throw away the remains, or toss them back in the water. Something will eat them. If I'm not camping, I take mine back to the house where I have a place on my dock over the water so the turtles, crawfish and fish get a meal too. Maybe others can help you out on fishing from a public peer or crowded beach. The few I have been to had places to clean fish set up. I do all I can to avoid folks when I'm hunting or fishing. :thumbup: The Golden Rule works in a lot of situations. I wouldn't gut a shark next to a family having a picnic. Three miles from the next beach gower? The birds, crabs and fish will have it cleaned up before anyone finds it. :D
They're fun, as are stingrays. A fella showed me how to deal with those too. As an added bonus, the barb makes a dandy little gig prong. I can post one of those is anyone wants to see it. Fishing and beach combing tomorrow, got rained out today.:mad:
The barb makes a dandy little gig prong. I can post one of those is anyone wants to see it.
I'd like to see the gig made out of sting ray barbs. That sounds like a great idea!
Is it single spike (flounder gig) or several sting ray barbs to make a three pronged gig?
What I saw was three barbs, bound to a single pole. It was in a Native American book I had. They were using it and a torch made from litard (fatwood) and wading for flounder. I wish I could find the book, but I have a perfect recollection of what it looked like. I'll work on getting some barbs.
That sounds awesome. The last thing I need is to have more abo projects on the backburner...
Richard J - I'm a retired chef and I would soak fresh shark meat portions in either a strong carbonate of soda solution (like 4 tablespoons to the pint of COLD water) for at least half hour, in cold milk/buttermilk for an hour or so.
Sharks, skate, etc all, in effect, piss through their skin and the urea remaining in the flesh will sometimes taste ammonia(ish) and unpleasant. The soak should take care of it.
