- Jan 23, 2010
Mark,
I usually draw the blade shapes on the sheet, and try and nest them together with as many joint cuts as possible ( one spine meeting another, etc.). I add smaller knives to fill any blank spots, and change the blade length or handle shape to make things fit better, or get a better steel yield. Sometimes there is barely any left over steel. This is on a sheet usually 24" to 36" long and 6" to 9" wide. I cut them on the band saw, but it takes some real cut planning....and a good bit of time. If I was to send such a sheet to you, can you work from the drawings on the sheet of steel? This is .060" S35VN
