I never thought of that but it sounds like a solution. I'll try it, thanks.I've never made knives but when doing woodwork I carefully and strenuously wipe off any glue overflow from the join using baby wipes while it's still wet and before it has a chance to set or go too gloopy and sticky.
I do use WD 40 on JB Weld in front of bolsters. No bolsters, just a regular handle and glue, I use acetone. Never tried WD 40 on regular epoxy. Got me a thinking now buddy.I thought horsewright used wd40 on qtips to wipe?
Ditto on the “check back several times during cure”. Extra will always seep over time, that time depending on how much epoxy you use, and how had you clamp
Hmmm. My little shop is inside, the fumes from acetone are kind of overpowering in that little space so I stay away from it. Ever since you taught me about wd40 on bolsters I guess I just reach for it for cleaning up the front side of everything (bolsters or scales). Seems to work fine, and has kind of a nice floral scent.I do use WD 40 on JB Weld in front of bolsters. No bolsters, just a regular handle and glue, I use acetone. Never tried WD 40 on regular epoxy. Got me a thinking now buddy.
I agree on the acetone smell, even in a large space I find it unpleasant. I'll try WD40 on the next wa handle instead of alcohol.Hmmm. My little shop is inside, the fumes from acetone are kind of overpowering in that little space so I stay away from it. Ever since you taught me about wd40 on bolsters I guess I just reach for it for cleaning up the front side of everything (bolsters or scales). Seems to work fine, and has kind of a nice floral scent.![]()
Have you ever tried 5 min epoxy? It is strong enough. Do you really think you can tell the practical difference between the measured psi ratings?Don't use 5 min. cure - it is not strong enough. IMHO, West System is the best because it has a small amount of flexibility built in. Wood and metal expand and contract at different rates with temp. changes and West System G-flex has enough flexibility after curing to absorb the different rates of expansion and contraction.
