Cleaning satin INFI?!
snwbrdr202
Hey fellas, I'm just wondering what everyone's input is regarding cleaning satin INFI. I had a satin Ranger RD-9 (see pic) which I could take the courser side of a sponge to, and it would turn out like new after every time I cleaned it (which was after every use). Can I do the same with INFI, or is there a better way to go about cleaning after a chop? I just want to avoid all unnecessary scuffing, marks, and the like as much as possible. I take extremely good care of all of my toys (cars, surfboards, knives, ect.), and I want to know what works BEST for INFI! Thanks for any input Hogs! :thumbup:
-Brendan
You, the proud owner of one of the toughest knives in the world, designed for chopping tanks in half and that sort of stuff... are you asking about how to remove scuff marks on it? Come on! :D :D
Just kidding. I just think that tools doesn't seem right just out of the box. Anyway, back you your question... yes, the sponge you used with your RD9 should work great. If that doesn't get rid of all the scratches... you can always try with one of those ScotchBrite wheels for the drill. I saw it done in this very same forum and it worked great.
Mikel
Another option is the Mr. Clean magic eraser.
It doesn't scratch the finish that I can tell and get's all the wood goo off.
The right Scotch-Brite wheel will restore a satin finish once you get whatever gunk is on the blade off.
I've found that the satin finish on INFI seems to be a little more susceptible to rust spots, so I've given mine a hit with some scotchbrite. It's not as polished as the satin finish once was, but the steel surface seems to be more resistant to corrosion. After a little wipe over with some sewing machine oil when I put them away, they go ang go and go. I guess it's because the microscopic marks made by the scotchbrite retain a little bit of oil and also build up a fine patina, thus giving the blade a protective barrier. But, I like a blade to look loved and used. :)
I choose Johnson & Johnson baby wipes applied gently to the rosy rump of your afflicted INFI will bring a smile to the ... crap, I'm drunk GO Earnhardt!!!
I have been cleaning up some old Gillette Safety Razors for use. One of the favorites for cleaning gunk off metal on the Badger & Blade forum is Scrubbing Bubbles. A tooth brushes and a little tooth pate can work. Metal polishes such as MAAS, Brasso, Nevr-Dull are popular with many. I have used just about all of these. The best one for you depends on how dull or bright a final finish you want.
Holy Hell...these are the toughest blades on earth. Spit on it and wipe it on your pant leg. DONE!
Magic eraser is what I use for the satin the most. Works pretty good, and does not scratch the finish.
ok, here's how i do it... really
go to a hardware store, get the 12x8" sheets of green scotchbrite, strop your satin finished blade straight, firmly and anally on that, spine leading, edge trailing. it works :thumbup:
If you have a drill & a vise, I've had good luck w/ these flap wheels. I picked it up at the local Ace hardware for 4 or 5 bucks.
firmly and anally on that spine :thumbup:
Post reported.:p
Seriously though, I usually just use a plastic dish brush and some detergant. Some gum cutter from the auto store (sprayed on a rag) or goo-b-gone should loosen the tough stuff... then repeat with the plastic dish brush and soap.
well everybody is anal about keeping their satin infi factory fresh. i do to sometimes but mostly clean the sap and pitch off with regular gasoline. in the long run you will be happier to just use it and let the factory finish go. :thumbup:
I used one of those when I stripped a CG knife, but found it way too aggressive. I think the paper is a really coarse grit.
