Would dish soap and a toothbrush be sufficient to clean this stone?
https://www.amazon.com/gp/aw/d/B015...=PK4BJH2REY9467XCTKF3&dpPl=1&dpID=91eh7RRfFeL
I'm very new to all of this. I'm not even sure if that stone would be the best for what I'm wanting to do (maintain a sharp edge on a carbon steel pocket knife).
Also, if I were to use mineral oil, do I soak it or put oil on top? Both? Then do I clean the oil off or will it all soak in?
I use Ajax or Comet powder cleaner and a blue Scotchbrite pad. It works great on regular Arkansas stones, but my ceramic is still grey, no matter how much scrubbing is done.
For the most part, it should do OK. If you use the stone with oil (mineral oil), make sure to use a little bit of the oil to lift and wipe away the heaviest part of accumulated swarf after each use, before giving it the dish soap & water bath. That'll be more effective. A toothbrush works well for scrubbing it with the dish soap & water, BTW. If the accumulation of oil & swarf is allowed to get too heavy on the stone, dish soap & water will have a tougher time cleaning it up; it'll need more scrubbing and perhaps repeated washings to do so.
For maintaining the edge on a simple carbon steel knife, that stone should be OK. If eventually needing to rebevel or doing some heavier grinding, an AlOx or SiC hardware store stone works very well on such blades.
Applying the oil to the stone, you don't necessarily need to soak it, but you can if you want to (it won't harm it at all). While the stone is relatively new, it'll drink up the oil a bit quicker until it starts to saturate with it. Just apply what's needed to keep the surface of the stone somewhat 'wet' and shiny with the oil.
David
So... Put oil on top, sharpen and add oil as necessary, wipe off stone (will paper towel work for this?), wash stone. Correct?
Basically, the purpose of the stone is to rub against the blade and remove metal. Slippery liquids, like water and especially oil, make the rubbing slicker, causing less metal to be removed, causing sharpening to take longer. On top of that, Juranitch claims that as your edge is being sharpened on the stone, the oil-suspended metal particles are washing over the edge and dulling it again.
So I found this...
"Basically, the purpose of the stone is to rub against the blade and remove metal. Slippery liquids, like water and especially oil, make the rubbing slicker, causing less metal to be removed, causing sharpening to take longer. On top of that, Juranitch claims that as your edge is being sharpened on the stone, the oil-suspended metal particles are washing over the edge and dulling it again."
Anyone tried both dry/wet with natural/synthetic stones care to give their experience? Is cleaning any different for a stone you've used dry than one you've used wet?
Does hydrochloric acid dissolve common ceramic stones?
