- Mar 19, 2012
So a while back I got the idea I would like to make a knife with a clear handle using carbon fiber as the base material and a celtic design and this is what i came up with, I'm super happy with the transparent design and the 3D effect, but not so much with the casting resin, I looked around and found a few different brands and decided to practise with alumilite because it was readily available at the local hobby shop.
The issues i'm having with the casting resin is it seems a little soft even after curing for over a week at room temperature, it can be marred with your finger nail, second issue even after wet sanding to 2000 grit and a quick buff with fin grit red buffing compound, there is still a haze on the piece, Is there a buffing compound that is better for plastic?
Third problem this casting resin seems to have a very low melting point, after buffing for a minute the piece warms up and can be dented with you finger nail, also it is still a tiny bit flexible at room temperature.
So I,m hoping someone could recommend a better resin, and a better buffing compound
Thanks for any Info
Thanks for any Info
