Clearance items to move
Feedback: +20 / =0 / -0
Toxic Little drop point
Price $80 shipped within the U.S.
Kydex Pocket sheath now included.
Full Tang
Handle- 3.8"
Drop point shape, full flat grind spine to edge ground
Handle material- Toxic Green G10 chamfered edges , G-Flex epoxy with 1/4" aluminum pins and 3/4" aluminum lanyard tube.
blade Steel AEB-L razor steel, Stainless composition like 13c26
Blade Finish is belt finish
Edge is V- grind on cardboard wheel system
Heat Treat in House, plate quench, sub zero freeze, 2 temper cycles,59-62 RC
taller blade and more belly Blade- .100x3.1" from front of handle cutting edge is 2.95"
Drop point shape, Multi color G10/ jade, forest, OD Green
A knife for outdoors as well as the kitchen!
Price $$$sold$$$ shipped within the U.S.
Full Tang
Handle- 4.4"
Blade- .100x3.4" from front of handle cutting edge is 3.4"
Drop point shape with thumb ramp, full flat grind spine to edge.
Handle material- Buffed G10, G-Flex epoxy with 1/4" aluminum pins and 1/4" aluminum lanyard tube.
