Esav Benyamin
MidniteSuperMod
- Apr 6, 2000
The Outdoor Edge Impulse had the clip in a groove, lowering its profile nicely, but not interfering with its function gripping a pocket.
Another alternative is the William Henry clipcase approach -- the clip attaches to an inside-the-pocket sheath. This leaves the knife clipless, but you still get the faster access associated with a clipped knife. I really like the way it works.
- Mark
Hi Vee,
In 1981 a new knife company caled Spyderco invented the use of a pocket clip (among other things) attached to the side of a knife for convenient carry and access.
By 1990, most of the industry had picked up on the pocket clip idea and now it is almost universal in the industry.
Some clips are better than others and some research will be necessary on your part to "catch up".
Hope that helps.
sal
Mark,
How do you get that to work? On mine, the clip on the case isn't as strong as the case's grip on the knife so every time I try to draw the knife I get the case with it. Not really a problem if you have both hands free, but if there's a way to make it work right, I'd sure appreciate knowing it!
Thanks, Mike
OK, dumb question, but you are putting the sheath inside and not outside of your pocket. right? If you are doing it correctly, then it sounds like you need to tighten the clip a bit. Just try bending it so that there is more tension on the clip. Also, with more sheath wear-in, the knife will get easier to slip out of the case. My two cents...
- Mark
Take a look at the Native III with its wire clip. It is very unobtrusive, and being round wire stock, smoother than the flat metal of most other clips.
Hi Vee,
As an ole fart (me) that uses clips regularly and has designed quite a few, I would suggest that you purchase A delica4. Use it everyday for a month. If you don't like it, I'll buy it back from you. VG-10 is very good, ZDP-189 is extraordinary (blade steel).
sal
