Anybody notice any difference in fit/finish between insingo blade sebenzas and clip point, be it blade centering, detent stiffness, lock stick, etc.?
Thanks!
There is no difference.
Your chance of receiving a Clip vs Clip or an Insingo vs Clip with a variance between the two would be the same.
My one Insingo is perfect in every way, but then again so are my Clip Points.
You just had a bit of bad luck with the first blade it seems. Had nothing to do with it being an Insingo blade. Sorry to hear about your trouble with it, and hopefully that will be the last one you have a problem with.
I know we're splitting hairs here. But take a look
Insingo
Same knife, clip point blade swapped in
This is probably a result from the grinding angles on the Insingo making it look off center.
I bought my large plain 21 insingo double lug about 16 months ago, and noticed immediately after receiving it the detent was too strong and the blade was a millimeter off center. On a tenacious or a cold steel I'd chalk it up to price point, but on a $460 knife I couldn't accept it, so I sent it back to CRK. 8 weeks later I got the knife back with a silky smooth detent and perfectly centered blade. The detent remained silky, but within 2 weeks the blade had drifted off center, and the knife was prone to minor lock stick. It bothered me more than it should, but on a knife this expensive With such close tolerances i expected next to perfection. I still carried the knife and just did my best to ignore these minor first world problems.
Well I used it a lot but decided one day I wanted a clip point, so I sent it back to CRK 2 months ago and had a double silver lug clip point with all silver hardware installed to the tune of $200. I received it last week and I couldn't believe how perfect the knife was when I got it back! The detent felt perfect, the blade opened smoother than the insingo ever did, and the centering, even after disassembly and reassembly, remains as dead center as could possibly be. The lock has had absolutely zero semblance of lock stick, even with minor flicking which i occasionally do because it's my knife and I feel like it!
Why can't they put an Insingo in a clip point but they can put a clip point in an Insingo?
They make loads of Insingos, what's the difference if they put a handful of Insingo blades on clip point knives? There's probably an equal number going the other way for those who decide they want the standard blade so it's likely a wash. Not like the market will suddenly be flooded with "Frankinsingos". It would be a way to get a nice inlay or graphic on an Insingo. Maybe they have some distaste for fancy handles coupled with Insingo blades. It would explain why theres only two handle options for Insingo (4 counting the KA and BHQ CF exclusives).
