- Mar 7, 2005
Cliff Stamp said:That is just silly for a folding knife designed to cut things. That is where I would run a large chopping knife if I wanted to be able to do power cuts into knots and be able to take heavy rock impacts and cold chisel cut metals without danger of primary grind damage.
Yes, it is really overbuilt for any real cutting, at least utility type tasks. I imagine that Benchmaed would say it is not designed as a utility knife, as evidenced by it massive size, very thick blade, etc. They would probably say it is built for self defense. Since my idea of self defense is calling the police or running away from a threat, that is the elast of my needs.
I like the looks of some of Benchmades designs, and reprofiling them isn't really a problem, but I can't bring myself to whack that much money for a knife that has to see a belt grinder when there are so many out there that are decent NIB.
True, it sucks having to reprofile. However, some of the other BM knifes, 940, 921 and 705 and the RSK have come with very fine edges.
However, the problem with the Skirmish, from a utility standpoint, is that the primary grind is too obtues, so the whole knife will need to be reground. Had BM gone with a full height flat grind, like the Manix and Militray from Sal, this might have been a great knife.
If they wanted to keep the sex appeal of the saber grind (for some reason it sells), then they should have used a high hollow grind like the Sebenza.
Nice shot of the Axis, well used, I would puukko-grind the primary right back down and then micro bevel as required. I did this recently to the Fulcrum IID, still can't cut thick media of course, but handles wood work, ropes, and such really well now and still has the insane blade strength due to the absurd stock and primary grind.
I got that in '99 or 2000 or so after reading Joe Talmadge's excellent article on making the Axis perform. I don't use it every day but when I use it is for hard work, relative to a folder.
I have probably lost like 1/15-1/20" off the height of the grind due a number of full edge resets, so the edge bevel is now climbing into where the primary grind used to be. The recurve of the balde is also less prominent then when it was new, though I have really tried to preserve it as bit.
Mine is an early M2 model and the heat treat is excellent, probably around 62-63 RC. I am not sure if BM has brought down the hardness to ease in machining.
When I do a full edge reset I use my Edge Pro, and need to lap the course stone after just resetting the worn edge, as it scoops a bit.
Rather the puukko grind it, I will probably just add a flat relief grind at about 8 degreess, an edge bevel at 12 degrees and a microbevel at 15 degrees. In the alternative, I could just convex the edge, thinning it down along with the primary grind.
BTW, rust resistance has not been a problem at all with the 710. I don't oil it, just wash it off after use. The BT2 coating (or whatever BM calls it) has held up suprisingly well considering the sue it has been put to.
I would really like to see a Ritter RSK made from the same materials, G10 and M2. THat would be an ideal carry knife for me.
