CLOSED: DulKnife - Wicked Edge Clone Knife Sharpener with WE Stones and Solid Surface Base
8-Fingers
Feedback: +527 / =0 / -0
I have a whole setup to sharpen your knives that I received this setup on a trade awhile ago, here is what is included:
1)
A DulKnife sharpening system (Wicked Edge GO clone) that came with stock 200/800 grit stones, the arms are right at 9" and are interchangeable with Wicked Edge systems.
2) An additional set of WE 400/600 grit stones (unused, still wrapped in plastic).
3) It is mounted on a piece of solid surface countertop that has finished edges and rubber feet underneath. The base is is a little bigger than the standard Wicked Edge offerings at 14" x 17".
4) Apparently the WE GO system has been discontinued and while this system is set up for home use, it could also be set up to be portable.
It has everything it needs to be a stand alone system or it can be parted out for whatever you have in mind. The delivered cost would be less than the set of additional WE stones and an equivalent base. I got pretty proficient with the SharpMaker setup so this unit wasn't really used... SOLD
