- Apr 9, 2017
I've just started making knives from old table saw blades. I am getting cloudy swirls in my blades during sanding. They seem to appear when I go to 220 paper. Bad metal? Bad technique? Help
You're not sanding with an orbital sander are you? 😋
It could be lots of things, but the most likely is that the steel is not the right type.
Also, your HT is not likely to properly harden steel. The steel needs to be hreated to around 1500F and quenched in something faster than motor oil. For a "backyard HT", try using an AO torch with a rosebud tip and quenching in a gallon of canola oil.
