CLR etching bath
Anybody ever try CLR for etching bath? I have tried Radio shack PCB solution works great but the one that I found to work really well to etch bath is real easy to find and use. It is "CLR" I was thinking what would be the opposite of a dark etch... using CLR would be the opposite, I think. well I tried it and I called it the "chrome etch" just sounded good. I bathed my blade in it for about 15 minutes, it bubbles for a bit. I used 80 grit then jumped to 220 grit finally used 400 grit, etched in CLR let it dry off then used a spray degreaser to clean off the CLR, I used a green scotch pad on an orbital sander then 3000 grit. what are some other etching ideas?
If you aren't trying to show something like hamon or hardening lines, then the only reason to etch would be as a surface coating, like a forced patina.
I've gotten good results with 44/40 bluing. Some say it could potentially be hazardous, but I've seen nothing that shows it's any different than any other oxidizing agent. Nobody worries about PCB etchant, and I guess you don't think CLR will hurt anyone. (I don't either) Once the surface is oxidized and neutralized, I don't think anything about it could be harmful.
I have found one thing that I haven't heard anyone else using.
I etch in PCB, neutralize, de-grease, then lightly buff with regular chromium oxide buffing compound. It leaves the steel dark gun metal colored, with a little shine. It seems to last longer than other forced patinas or bluing, or maybe I just take better care of it because I like it.
I use lemon juice. Its great for getting the whispy whites to show in a hamon.
You found someone else. I only etch damascus though, and I hit it lightly on the buffer to make the high spots shine just a hair more.
