Nice score on the Crawford staff Brian. I know where there are a lot of other useful things you don't need so watch out. You might be spending more once I post links.![]()
Yeah but....... a guy can't have enough neckers.....Ron, now that you posted on a public forum that something that is as valuable as a Horton Necker will be at your front door, don't be surprised if it is not there when you look.BTW, you already have a Horton or two also.
Pluck, the leather lined kydex sheaths rock, I order them with every knife I get from Jeremy. Perfect retention, almost too tight, but I like it that way - no rattle, no wobble. Just don't have Josh dye the linig, my OJ Necker's blade isn't so OJ anymore, got black spots from the black lining.
Well....cleaned the chamber on the AR..........ran some remington threw it.....it started out a little better but is still fubar............One round in the chamber without the mag and it fires and ejects. Put the mag in and jammo.......mag change didnt change anything. This rifle has a new collapsable stock with new buffer spring and buffer. Now im thinking too strong a buffer spring or dirty gas tube/vent? The cases arent market like theres a chamber problem.................Now the bad part.... the rifle has a 11.5 inch barrel with the welded on 5 inch flash hider..........i let Jeremy weld it..........hes not a welder........its gonna take a lot of grinding to undo the weld he did.........if he had welded on the Titanic it wouldnt have sank..........unless it went down at the dock from the weight of the welds, anyway people would have been saved.........
Im not an AR guy........my AKs run all the time so dose my Daewoo............so any advise will be greatly appericiated..
Thanks guys
I wonder if some magic smoke will help............
Interesting, you've try different mags? They all do the same thing?
Strange problem indeed. When they do eject, where do they land?
4-5 feet away, to the right and behind me.....
Can you clean the gas systen without pulling the gas block? I really think to get to the vent hole ill have to pull the block completely off which means grinding off a big unly weld................wait a minute, is that a bad thing?
