- Jul 11, 2007
For the metallurgy experts out there! Which steel is better, CM-154 or AUS8? What are the characteristics of each?
Thanks!
Thanks!
From Joe Tamade's Knife Steel FAQ:For the metallurgy experts out there! Which steel is better, CM-154 or AUS8? What are the characteristics of each?
AUS-6 - AUS-8 - AUS-10 (aka 6A 8A 10A) Japanese stainless steels, roughly comparable to 440A (AUS-6, .65% carbon) and 440B (AUS-8, .75% carbon) and 440C (AUS-10, 1.1% carbon). AUS-6 is used by Al Mar. Cold Steel's use of AUS-8 has made it pretty popular, as heat treated by CS it won't hold an edge like ATS-34, but is a bit softer and may be a bit tougher. AUS-10 has roughly the same carbon content as 440C but with slightly less chromium, so it should be a bit less rust resistant but perhaps a bit tougher than 440C. All 3 steels have some vanadium added (which the 440 series lacks), which will improve wear resistance.
ATS-34 - 154-CM The hottest high-end stainless right now. 154-CM is the original American version, but for a long time was not manufactured to the high quality standards knifemakers expect, and so is not used often anymore. Late-breaking news is that high-quality 154-CM may again be available. ATS-34 is a Hitachi product that is very, very similar to 154-CM, and is the premier high quality stainless. Normally hardened to around 60 Rc, it holds an edge very well and is tough enough even at that high hardness. Not quite as rust resistant as the 400 series above. Many custom makers use ATS-34, and Spyderco (in their high-end knives) and Benchmade are among the production companies that use it.
Ok thanks! I am looking at the SOG Tac knife which is a hefty $100, but it uses AUS8. Anyone have experience with SOG's AUS8 steel?
Don't quote me on this, but I believe that AUS8 is a softer steel which rusts easier, it should be easier to sharpen, but will hole an edge for less time. 154cm does not have the best rust resistance but it is better than AUS8's in my experience. THis may not go for all knives, but looking at my griptilian in 154cm you can see lighter and darker lines in the steel which gives it a striped appearence, whereas a cold steel knife I have in aus8 is more uniform, having a consistant silver all over. Most people consider 154cm to be the better steel, but for someone with limited sharpening skill, the aus8 might be a better choice. Also knives in aus8 are usually much cheaper than their 154cm counterparts.
Most manufacturer's websites will have a chart showing what each steel contains, and what those elements do for the knife.
Thanks!
I'm an apparent minority here - I think it's 154CM buy a long shot when made by a reputable mfg.
But AUS8 is still an excellent blade alloy. Even in manila rope cutting tests, it has better edge retention than 440A or 420HC
That's really not saying much. All three steels you mention are, in my very humble opinion, bare minimum cutlery alloys, not excellent ones. They're selected by manufacturers more for their ease of machining than their end performance. Ever notice you don't see them in custom/handmade knives?
You mention 440A... 440C is a BIG step up. 154CM is essentially 440C with added molybdenum for even better corrosion- and wear-resistance. It's not appreciably more difficult to sharpen.
It is true, however, that properly treated AUS8 can take a nice edge and is relatively easy to sharpen. But it is not a high-end steel in any way. 154CM and especially CPM-154 are definitely high-end and well worth the cost.
If im not mistaken caldwell is useing 154 in their customs.That's really not saying much. All three steels you mention are, in my very humble opinion, bare minimum cutlery alloys, not excellent ones. They're selected by manufacturers more for their ease of machining than their end performance. Ever notice you don't see them in custom/handmade knives?
Thanks!
