I use the easel inventables for doing guard blanks for hidden tang knives on my CNC. It's an easier CAD/CAM software to use and lets you select bits, materials and gives recommended speeds/feeds for them. It has options to allow cutting on the line, inside or outside the line, so I think it would be somewhat easy to get shields to fit well into the pocket you can mill out? I use a 800W cnc mill setup with all linear rails, but not ball screws or closed loop steppers and it has no problems machining thru up to 3/8" thick Micarta or G10. I haven't tried aluminum or other metals yet.
I also use easel inventables for making templates to use with my laser. I set the cutting depth to match the material I am cutting so it does 1 pass, sent it to cut on the line and export the G Code, which can be opened by LightBurn. This way I can laser out wood templates to test my DXF files, make prototypes/templates, make sheath patterns to cut out from leather, or do wooden knife stands. I can also laser onto steel the profiles I want to cut out so I have cutting/drilling lines/circles marked out.
I know a friend of mine used his CNC to profile out folder blades, .05" per pass, about 10 minutes for a 3" ish blade in .08" thick steel, including a large oval thumb opener cutout. Not sure how long a router designed for wood will last doing that? I know I can upgrade mine to a heavier duty water cooled spindle and VFD, closed loop motors and ball screws, but it works fine for G10 and Micarta. I have access to a makerspace type thing at work with a CNC mill and manual mill, too, that I need to get clearance/training to use as well as their waterjet machine!
