Is there a coating that can be sprayed inside the kydex sheath to slow/stop the wear on blade finishes?
I've been told that some coatings used (duracoat) on the knife that are sprayed/baked, can also be sprayed inside the kydex sheath (not baked of course).
I need to find a coating that can be applied prior to making the sheath (will not come off after the sheath is heated/stretched) or find something to spray inside the sheath afterward that will dry and not peel off and still allow the knife to be pulled without causing wear on the blade finish.
