- Aug 28, 2017
I just bought some of the F size in a 12 pack. I used one today and it’s the worst hole I have ever drilled with a new bit. My old wore out bit drills a nicer hole then these new ones.
Are they the same as the ones I got? Those were only available in 10-packs. I got some 1/4" as well, but haven't used them yet.I just bought some of the F size in a 12 pack. I used one today and it’s the worst hole I have ever drilled with a new bit. My old wore out bit drills a nicer hole then these new ones.
Lubrication is why industrial folks get a thousand holes a bit.
Most hobby guys burn the bit up in a few seconds and don't know why it stopped cutting. They say, "I gave it a squirt of Molly-D, and it didn't help". They don't realize that the lube was smoked off about three seconds after applying it.
Flood coolant is a far different thing. I am setting up my drill press and metal band saw in the new shop for flood coolant.
Don't get me started about the shots on FIF where they have the drill bit so hot it is red ... and can't get it to drill (or weld it solid in the hole).
On metal band saw , ok .But why would you do that on drill press ? For three hole in thin steel ,from time to time ?Flood coolant is a far different thing. I am setting up my drill press and metal band saw in the new shop for flood coolant.
Most new knifemaker have no previous experience in working with steel and there you go .......Hundreds of topic how to drill hole ,which drill bits are best ........etcI haven't done an experiment to prove this, but I expect I could probably get a similar number of holes cut dry if I were to reduce my speeds to eliminate heat issues. I really think the real reason industry gets more holes from a drill is controlled feed. I think that amateurs in their garage tend to underfeed during most of the hole leading to work hardening and abrasive wear and then over feed once the web of the drill passes through the back of the work which wipes out the corners of the tool. I think knifemakers would get better results by optimizing the use of the tool, not by the use of special fancy tools.
Best coolant system on world will not help if you use wrong speed and feedCoolant is a game changer. Correct speeds and feeds are essential too.
I like the HSS twist drills from Lee Valley.
