- Oct 10, 2002
Cobalt talked to me at Blade about rehandling a few knives for him so we went around and picked out some green Micarta. He then sent the four knives, a special SHBM with a birds beak end (which the Busse Custom Shop added, not me), two 2007 SE Mean Streets and Culti. He also sent stainless slotted bolts to be used for the handles, I knew I was in trouble then! I hadn't used the slotted bolts before because I knew they were going to be a pain in the a$$ to get the slots lined up and still have the slot show after the handle was ground to shape. So, the following pictures and posts are how I did it.
Here is the SHBM as it arrived with the black and grey G10 handles.
Here is the S.E. MS with the black and grey G10 handles removed. You can see that the double cut was applied after the handles were attached.
The only size of stainless slotted bolts I could find had .216" stepped shafts. These would have made a sloppy fit as the hole in the handle is .250", so I had to make bushings for all three knives!
The micarta handle has been roughed out. You have to do the front and back part first before attaching it.
Next, I had to mill the handle slabs close to the final thickness.
Here they are after milling them down.
