Cobalt's ménage à trois + one...........
These look great Tim! Awesome Job :thumbup: Most people don't realize how time consuming it is to fit and shape new handles from raw slabs of material. In your case...those slotted bolts took even more time. :D
Well, I'm no expert... But they look pretty frakkin' good to me! :D:thumbup::thumbup:
Nice work!:thumbup:
When I first started reading the post, I honestly felt a little nervous about what was about to come, but they all turned out really fantastic! Wow!
Tim, that's some great work. You've really come a long way in your craftsmanship since this one:
attachment.php
My response is also-WOW!! Slotted bolts that align! I'm not sure if it is ever possible to improve on Randucci's work. Really great work there.
Tim, that is truly incredible work. Thank you for taking the time to share with us.:thumbup:
Matching slotted screw angles? Outstanding!
I calculated the angle of alignment to coincide with the Mayan prediction of the end of the world in 2012. Cobalt might be able to save the planet if he can figure out the proper alignment of his three knives and one special SHBA! He has less than four years to figure it out. If and when he does, he will have to place them carefully in his Porsche 996 (if he ever stops putting all that gingerbread on it) and achieve a speed of 200mph, thus thrusting the knives and himself into the 5th dimension. Once there, he can speak to the Mayan Chief and find the secret to stopping the pole re-alignment, Asteroid, Nuclear war or ?, thus saving the planet! I might have said too much, I can feel (since you can't "hear" them) the black helicopters outside, errrrrrr, I got to go.........................................:eek:
I think ... you've got it down to a science. :D;)
I predict that, one day, you will again perform a similarly exacting task. When enough time passes, so does the irritation. :)
Well, I will pull out the mayan calendar and align the three knives in a triangle set well on an 18 inch cheese pizza to keep them from moving. With the slots facing the four corners of the earth, I will then travel to a speed of 201.2 mph at which time a wormhole will open allowing me to look into the future and see what causes the earth to self destruct. I'l go do it now...brb....(3hours later, but because of travelling back in time it only appeared to be one minute I have gone to the future and been back) I have seen it. it's too horrible to discuss. it was the clone wars all over again, except these clones were patterned after Jerry Busse and Gary Busey. And while all the Jerry's were drinking scotch and smoking cigars, all the Gary's were smoking crack and banging their heads against walls while the Jerrys layghed at them saying that the Garys reminded them of Teabags. The entire planet was engulfed with fumes from cigars, crack, and methane. The earths atmosphere had turned a dark brownish green and all animal and plant life was gone. Only rats and roaches were around and pockets of humans hiding from the Jerrys and Garys. Maybe we can stop this now.
I think that if you went back with enough CBL to extinguish the cigars, crack and smother the methane gas, we might be saved. I'm worried that the 996 won't have enough room for all the CBL needed. You might need to get a Cayenne GTS with its greater capacity. Take the huge turbos off the 996 and maybe then, the Cayenne will make the 201.2mph requirement, good luck, we are counting on you!!! :eek:
