Thanks everyone for the replies. This cocobolo had to have been still not cured enough because these two knives have seen very minimal use and are still in the same area where they were made which leaves out the temp/moisture change.
All wood will be affected by changes in temperature and humidity levels.
Example: if a 1/4" scale that is damp is left laying flat eventually the ends of the scale will curl upwards as the moisture evaporates from the top side faster than the bottom side. If this happens, flip the scale over and let it sit a while. This allows moisture to evaporate from the other side. Continue to flip over the piece in 1/2 day intervals until the movement stops.
Stand them up on edge, so both sides can dry evenly.![]()
