I had some relaxing time this morning, so I took the handle off of my third (and last) 1917 Frontier Bowie specimen. Now that I have done an inspection and cleaning under all three of their hidden tang/handle areas, I can comment on what I noticed about them.
For one, they were all stamped with the words "COLD STEEL' on their tangs. Some of this lettering on each one was diminished or slightly ground out (seems the markings were put in prior to all the final metal grinding, and hence some of the diminished lettering).
They all had different numbers stamped in. Two had three digit numbers, the other one had a two digit number (likely numbers for each in any given production run).
All three have a half inch long weld spot area on each side of the guard (securing the guard permanently to the tang/blade).
The two bowies made of 1085 steel had cleaner looking welds, with the 1055 version being a bit less so.
All three handles had slight cut-outs for the welds where the handle would butt up to the back of the guard (these cut-outs obviously there to allow room for the weld spots).
The two 1085 steel bowie tangs were bone dry under their handles, but not a spot of any sort of rust, none whatsoever. On the other hand, the 1055 steel version, while also bone dry, did have some minor surface rust that required a little bit of oil and steel wool to remove. The rosewood handles on all three were machined to fit snug onto the tang, all needing some taps with the palm of my hand to remove and re-install. All three have the same type of male into female threaded screws. They all had some glue on the threading (likely to do what loc-tite does). That said, none of these screws gave me too much trouble while removing them. I did clean them off before re-installation.
I would not worry too much about there being a need to remove the handles on these bowies, although it's an easy enough task if you feel like giving the hidden areas a once over for some preventative care.
My 1055 version definitely benefited by my doing so, having that slight surface rust that could have been less slight as time went on.
The more I get acquainted with these specimens, the more I like them. One can really see the little things that point to them being hand made items. In today's world, where production is advanced to require less and less human effort, these give an example of what used to be the norm in manufacturing of such things. I like having such representations in my collection
