- Jul 19, 2011
Gaston, what color is the sky in your world?
I should elaborate. The mortise on a lock-back is exposed when the knife is closed. This allows access to any lint that may have accumulated. It can be easily removed with a small pointy object, such as a toothpick or Donald Trumps winkie.This is to allow for the presence of pocket lint which can easily weaken or disable this kind of lock. Here the lint has a space to get squashed into and not impede the mechanism.
Gaston
Gaston
I should elaborate. The mortise on a lock-back is exposed when the knife is closed. .
If you're all concerned about the lockup and the linfcompressor, buy another knife, stay away from lockbacks, stick with Framerame, locks, Axis locks, Walker locks, Rolox, Swivel Locks, Funny folders and Slip Joints.
I don't get it, if you're so concerned than give it away, throw it away of put it away but you semi so adamant that it's an issue and a potential failure. Just buy a fixed blade and you wont have to worry about it.
gas, I've been using lock back spring in a few different configuration and in 40 years I never had a failure and any lint in the recess I was able to just blow it out. What are you doin'g that you're afraid of lock failure? If used properly there's always pressure holding the blade open against the spine. I'm not sure how you misuse your knives but you might wanna consider picking up this book to teach you how to properly use a knife. I always thought you might know something about the proper use of folding knives but it's become very evident that you need a refresher.
R u drunk? I dont care. I would just put it inside even after cutting belt to get outa crashed car or sh!t having arterial blood loss to get to docs asap. Time counts.and a lot of knife owners, clean the lint from their pockets prior to carry.
hell. WHY. I WANTED SWIFT.loosened the pivot just a bit and looked down inside and did not see the usual flat spring.
Someone please address how you can make it open easier. If you loosen the main blade screw it throws the blade off and oil does not help.
Thanks,
