Cold Steel Bushman Destruction test video (links at bottom)
Ive had a Bushman lying around my shop for a year, using it for
Various tasks. I decided to see how tough it really is. I think you will be shocked ? I was.
Fist I placed the tip in the vive and did a bend test. I was easily able to get the blade to bend about 20 25 degrees. I did this 10 times. The knife didnt break and no tip failure.
I proceeded to hack into a 2x4, cutting through it. Then, I hammered the back of the blade into the wood. No blade failure at this point.
I moved onto the landscaping brick hacking away. The sparks begin to fly.
I hacked for about 10 minutes in to this brick cutting a V notch. The edge never chipped Just dented. After this I was getting tired and the knife keep going.
I begin to hammer the back of the blade into the brick chipping away sections and splitting the brick. No blade failure, just denting very little actually considering the time evolved. I then hammered the tip in to the brick and the tip bent.
I moved on to an old metal chair. I hammered the tip strait. Then thrust it in to the chair denting the seat. The tip bent. I hammered the tip strait and continued. I moved my attention on to the chair hinge trying to cut through it. Finally there was a thumb size chip in the blade.
I continued pounding in to brick and wood with a 3-pound mallet. Still no major blade failure. I secured the tip back in the vise and bent the blade about 30 plus degrees many times. The blade still refused to break.
Back to more hammering and pounding. I hit the knife every with way top, side, back still the blade would not give.
I finally beat the back of the blade against the vise and the blade broke.
I moved on to the handle placing it in the vise and pounding on it breaking the last 2 inches of blade. No handle failure. I place the handle on a 2x4 and beat it with a 15 pound sledge. It had no affect on it. I was determined to destroy the handle but I was afraid to place it back in the vise and pound it in fear a breaking my vise.
I putt the handle on my 12-ton hydraulic press hoping to crush it. I pumped the hydraulic ram applying extreme force my best guess is about 10 tons. The press was under extreme tension. The handle looked crushed from the end however when I released the pressure it sprung back to shape. Pretty impressive considering I use the press to crush iron pipe with ease using only a small fraction of the force applied to the bushman handle.
I decided that I wasnt going to be able to destroy the handle without tearing
up my shop equipment. I called the test finished.
Overall: The cold Steel Bushman is one tough and I mean tough knife.
It took 54 minutes of brutality to break it. Unreal; considering it only cost me $16.95 new. Check out the tip it is still intact. Awesome!
Note I didnt perform any cutting test (paper, card board, ect.) as I was testing. I can sill cut cardboard sawing thru it, using the broken tip end section.It is not on video; so dont take my word for it.
On the Becker Bk9 and K-bar USMC I will performs cutting test throughout the videos.
The video is in 5 10-minute parts. Part 6 is about 4 minutes.
Hope you enjoy the video? This one was tough !
http://www.youtube.com/watch?v=fnDL7PlEI_Y PART 1
http://www.youtube.com/watch?v=JBSH8XXFwD4 PART 2
http://www.youtube.com/watch?v=sId10Ml0JDE PART 3
http://www.youtube.com/watch?v=OK51RdigNTA PART 4
http://www.youtube.com/watch?v=skJEE3-1laA PART 5
http://www.youtube.com/watch?v=hlUz7FhAU70 PART 6
