- Sep 9, 2015
could i weld a piece of a pipe onto the blade of the natchez bowie to make it stronger for chopping wood or would it break or ruin the steel
You could put the blade on the ground and beat the **** out of it with the pipe and then pitch it in the trash. Not saying it's a bad blade at all I just hate cold steel as of late. In fact I think most custom knife makers have strong feelings about them as a companey that's not to kind. But as to your original question, my advise is to keep the welder away from anything that is blade steel. The only time blade steel is welded is when making Damascus and it's done in a forge. The problem with welding steel that can be heat treated is the weld will most likely crack as it cools. This is because the weld mixes with the high carbon steel and it cools so fast that it heat treats its self but there is so much stress from shrinking that the weld can't take it and cracks. If it does not crack then there is s chance it will when any load or force is applied to it. Generally if you have to weld to a high carbon steel then you pre heat the steel to a temp that alows the weld to cool slowly and evenly. This pre heating is usaly hotter then you would want to heat a hardened blade to because it would most likely ruin the heat treat or at least drop the hardness of the steel. A much better option is low temp silver solder in the 400° range which is what I use for attaching guards to blades.
The second picture would work, it's called a box handle. Shape a piece of metal into the shape of the handle you want, then shape it to fit your tang. Drill one or more holes in your tang for pins, and do the same with the box handle. Then solder or use JB Weld to re-enforce the two pices, apply your wood slabs and pin. Tighten it up until the glue takes, and you have a new handle. But welding? Nope, I wouldn't do it. Too hot and it will ruin your blade.Here is picture of tang and I don t see problem to extend and weld piece of steel .............brazing would be best way...........
Or something like this...........
If you are determined to weld it, put the blade upright in a container of cold water up to the guard. That may prevent the heat from reaching the blade. Good luck!I think it's far enough away from the blade to ruin the temper and that can be weld . He can protect the rest of tang from temperature if it is necessary ? And there is massive guard that will take some of temperature........
