I don't WANT a flipping balisong, but the Paradox looks to have the potential of being about as strong a folder as you can get. It's about 6oz with the stainless milled handles and looks to be very solid. The springs look strong & tight. In fact, just about the only thing keeping me from clicking "buy now" is the possibility that those springs may be too tight and make it difficult - or even dangerous - to open & close easily. Think it'll be clumsy? Has anyone actually owned or handled this thing? Thanks for the feedback! Enjoy your knives.
With the Paradox however, the only advantage is the "lock" strength.
Actually, now I don't think this is true. The Paradox spring mechanism with the pivot is nothing like a balisong, but more like a slipjoint. A balisong uses either a pin in the tang or pins in the handles (zen pins) to keep everything where it's supposed to be.
If you watch the video CS put up on the Paradox, you can see where and how the knife fails under an extreme load.
A true balisong wouldn't fail like that. To make a balisong break with that kind of "test" would require the handle itself to snap or shear. Probably where the pin hits them - called the tang cups, or if it's the kind with zen pins, probably where the pins are, or at the pivots themselves, as those spots would be the weakest.
I'm not sure I'm following, Planterz. It looked to me like the Paradox had pins in the same place as a balisong; it just has springs, as well, while a true balisong swings freely. And in watching the video, it looked like the Paradox started to move in the same way a balisong would. The handle dropped because the handle parts shifted, as there was nothing gripping them together; but the pins held as they would on any balisong. I wouldn't say the knife "failed" as much as two independent parts shifted in place until the top handle piece stopped where it hit the base of the tang...at which point, the weight was resting in large part on the top pin. I wouldn't call that a "fail" at all.
Now my question is- what if someone got ride of the springs and all that bs after they bought it, put it back together- then wouldn't that have a latchless balisong?
theres no tang or zen pins so the only thing stopping the handles while swinging freely would be the opposing pivot pin, this also answers why it bent at a 40degree angle and stopped the handle hit the opposite pivot pin.
now if you drilled and tapped the blade and added some tang pins or welded a bit onto the blade and put zen pins in it would be a full fledge bali, though that would still leave an opening where the spring was, but i dont know if that would affect any as i dont have the model in hand, but now that ive talked about this i kinda want to turn it into a proper bali
edit: there is a chunk of metal missing where the normal tang and tang pins would be so you would have to cold weld a chunk of metal onto the bottom for any pins to work, which doing so would run the risk of ruining the temper on that Aus8
