Why does it have a cable tang? Is it somehow better than full tang?
But do you know if its better than full tang? I have a huge problem paying almost $200 for a knife that's not full tang
Okay- I have not commented officially from CS in this manner, since it seemed that most here could see that this was not the fault of the knife, or the design, but when some start calling this knife "garbage" and are clearly misinformed, I now have to comment. The cable-tang on the Natchez and the Laredo is there intentionally. These are primarily fighting bowie knives and are designed as such. The cable-tang is actually a more expensive process than a standard full tang or a full "push" tang. We did this to both lighten the handle, giving more weight and impact inertia to the blade, and to distribute shock easier through the handle, since the handle material is hard vs. the softer Kraton handle available on a knife like the Trailmaster. While CS considers batoning to be abuse of any knife, and not what knives are generally designed to do, if the OP had batoned the knife on the spine, I do not see how the handle would have split and shattered the way it did, especially considering that the cable-tang is DESIGNED to distribute energy out the pommel- like the vibration of a guitar string. While translation may be a factor, it does appear that the knife was hammered on the pommel like a nail- that is absolutely abuse, and even with a push or standard full tang, it would not be surprising to have the handle fail under those conditions. All this discussion is pointless, however, since none of us has the knife in hand, or the exact conditions of the break clearly outlined. Yes, the OP should send the knife to us for evaluation, and if it is a defect in material or workmanship, it would be covered by the warranty. If not, we may be able to repair it. Don't know until we have it in hand. For those who do not like the cable-tang design, that is certainly acceptable and your choice, but the design is expensive, very tough, and made specifically for those two models. CS R&D crew made this decision with intent, and it has proven to be extremely successful. I would encourage you to not let this one unclear, though abusive, incident color your judgement of the entire line.
The mylar blanket you keep in your altiods tin?to baton, or to not baton. The big question that drives so many knife discussions.
I carry a knife, a saw, and an ax. Guess which one I chop wood with?
If a Bowie that size can't be used as a chopper, it's virtually useless. Claiming it's a fighting knife doesn't provide any cover. What kind of clown designs a knife specifically for fighting, that can't be trusted to chop? If you can't rely on it for the latter, heaven forbid you ever get yourself in a position to use it for the former. As far as I'm concerned, that Natchez Bowie is nothing more than an overpriced man bauble to be admired in a case or part of a costume.
