Ridiculous knife.
I found this review, which added some new dimensions.
It's amazing that most of us live in a country where we can carry these things. I live near Washington, D.C., where the laws change suddenly to a limitation of a knife blade to 3 inches or less, no serrations. With Washington's amazingly low violent crime rate, perhaps other cities should pass similar laws! But in Virginia and Maryland, knives like the Spartan and Rajah are no problems in carrying, and they do make good trail knives.
I love it! LOLOL
My "Zombie defense fund" however is for a Saiga 12 gauge! Heh Heh Heh!
Well it seems that the knife does have a cult following.
I have many Cold Steel knives and though some complain about their choice of steels, the one thing I can say is that it you get a knife with 440A, it'll be the best 440A you can get, period. And the same thing's true of AUS8. I've had my share of Bökers and CRKT knives and none have as good a heat treat as Cold Steel's. I bought one Böker 440A knife about a year ago and it won't take an edge no matter how much you try to sharpen it. A couple of swipes with a Cold Steel and the blade will cut your hand off! I have a box full of Voyagers of various sizes and configurations, and all of them came with blistering sharp edges. Seems to be a thing with CS knives. All of them sharpen extremely well.
Charlie Mike seems to like tantos, but I'm not sure I prefer his design. It's different, though. If the Spartan was available in a Bowie-style blade, I'd probably get it. But not tanto.
Excepting collectors, hunters, LEOs, EMTs, first-responders, and the military: In reality, all most of us really need are; an SAK, a small slip-joint, a multi-tool, and a small fixed blade. The rest is just indulgence.
The only other folder I think would match the large tri-ad lock folders would be the Extrema Ratio RAO.
I thought I read that people were having trouble with those when using them like a fixed blade?
I have yet to come across one documented case where a Tri-Ad lock failed in the field. People say that no folder is as strong as a full tang fixed blade knife, but while technically true, the Tri-Ad lock found on the Spartan and the Rajah (and others in Cold Steel's new line-up) are more likely to fail in the blade, not in the locking mechanism. Until a documented case of lock failure is posted, the knives can be regarded, in my view, as strong as fixed blade knives of the same size.
