Funny, it is a "underground" CS review site. Look at the Pocket bushman review he shows how "we" fixed issues with it. Now Lynn has others doing it for him?
DemkoKnives - Question if you have the time: What is the smallest knife you have used that lock in?
Most of the knives with the Triad-lock are "manly" big, but I wonder if the design lends itself to smaller, more pocket friendly knives.
STR, the new g-10frame(linerless) lawman is as strong as the original lawman.
in weight hang tests. The blades or pins break before the frame does, As for the spartan, it has a grivory frame so it benefits more fron liners than G-10.
As a side note, the g-10 only frame has more radius on its edges do to the thicker g-10(about .187). Making a much nicer grip.
The Rajah II is still my favorite Tri-Ad knife. My Spartan is also very strong, but the mainspring is too damn stiff! Many times it takes both of my thumbs to depress the spring, so discreetly closing it can be a pain. (Both of my Rajahs work fine, so it may be the luck of the draw, who knows?)
The Spartan will provide raw strength -- nearly that of a fixed blade knife -- and for an aggressive outdoor knife, the Rajahs and Spartan are my top choices; but for EDC, the Voyager 5-inch is hard to beat from a strength/size standpoint. The Spartan is a very rugged knife, though, and is a phenomenal outdoor knife. It would be an excellent knife for a bug-out bag or for camping. For city use, you would do well to have a Spartan in your tool kit, the trunk of your car or even yard work.
The Rajahs also fit these uses. Both the Rajahs and Spartan are aggressive cutters and any carpet layer should probably have two of each. Cutting carpet is rough and tedious work, and you don't want to be cut by either the blade or the carpet. And the Spartan is the ideal carpet cutting tool, as the blade is sharp and tough and the handle extraordinarily secure, plus it protects the hand at whatever angle you're cutting at!
Other Cold Steel knives are adequately strong without being quite so massive, though, and discression may dictate buying a Voyager or Recon-1. When you need the beef, the Spartan moos big time!
