It's a dilemma for the manufacturer. Some of their customers want to be able to take apart the tool for modifications. But most want to buy a tool that stays together for the life of the tool. Difficult to satisfy both groups. Economics demands building for the lowest common denominator.
Drill. Easy out. Hope.
you could try the soldering iron, set on high. or, if you or someone you know smokes cigars use a torch lighter.
Give our team a call toll free at (800) 255 4716
They may have some suggestions.
Thanks
Cold Steel moderator,
With years of real world testing and tons of feedback by your customers isn't it time for Cold Steel to make the set screw go away? Except for the most inexperienced outdoorsman/woman or the youngest pre teen user; no one, anywhere, any time, on any forum, in any discussion, has ever spoken positively about the set screw.
It is technically incorrect for the friction fit tomahawk and in practice that tiny set screw mounted directly in the wood haft has zero chance of performing the desired function. It simply could not work fo any length of time without wallowing out the wood and becoming loose. So why the resistance removing it? For a company that has so many great products and coming from a big fan of Cold Steel products, this one is a real head scratcher!?!
It is an incorrect part for a tomahawk, it cannot and does not perform the intended function and your customers not only hate it but, as a matter of fact, it is removed and discarded the moment it comes out of the box. That is, if you can get it out. Can you please forward this to whoever has the ability to make such decisions?
