hi all,
i recently bought a Cold Steel Recon 1 straight edge tanto through the mail, (i am now pretty down on getting things through the mail).
when i got it there was a small surface scar (slightly larger than the head of a pin) in the teflon finish on the blade (i am a user and not a shower so i just winked at it). then about a week later i went to open it and the lock jammed and the blade would not come out of the handle. i then got the lock unjammed and put some gun graphite on it and it worked just fine. then about a month later i went to open it and the blade opened all the way but the lock refused to lock the blade open, making it extremly hazardous to my fingers. i then put some more graphite on the lock mechinism but it would still refuse to lock the blade open on occasion. i then called CS and explained what happened and they said send it in with an explanation. i sent it in and then after thinking about it i realized that the seller might have sent me a knife that someone returned after they screwed the lock up. i am further convinced that they sent me a returned knife because, when ordering on the phone, they at first said i was out of luck to get one but after a few minutes of holding (at their insistance) until they checked, they "amazingly" found one. if i had realized that, before i sent it in, i would have told CS about it. they then might be more apt to replace it then fix it (cutting down on the time it takes). now they may not want to give me a perfect knife instead of a bitched up one (i should've got a perfect one from the seller).
has anyone else had a problem with the locking mechinism on a Recon 1?
(i am otherwise extremely pleased with the knife)
sog
sog
