Cold weather survival knife recommendations
Kelby Coffelt
Basic Member
Hello all,
Looking for some cold weather survival knife recommendations. Price isn't a huge factor, under $300, 3-6 inches. Multi use and durable are extra points. Uses include general ranch/hunting/winter camping. Have a cold weather school for the army coming up as well, might try to see if I can use it for that as well.
Thanks all!!
I'm not sure what makes a knife "cold weather" but the things I think of are a good sized ergonomic handle and lock thats easy to manipulate with thick gloves on. You didn't say fixed or folder. But folders you might look at the shaman or military 2. The big hole and compression lock would be easy to use with gloves.
Spyderco Military, designed specifically for use with heavy gloves.
Stromeng Leuku fixed blade. The lapinleuku is a fixed blade design refined over many years of use in the cold environments of the North by the Sami people. The Stromeng leuku is Norwegian Military issue also, and if anybody knows about cold weather survival its those guys.
Whats wrong with your issue knife?
1. It's what you'll have
2. It's supposed to be able to handle cold weather
3. You dont developed confidence your equipment unless you use it the field environment
In old days we trained with issue and carried other items for testing IF we wanted to pack xtra weight
Peltonen - Finnish military issue. Built as a general purpose / defensive tool. All weather rated and fairly priced.
Sheath will be equally important.
Kydex can crack in extreme cold
Some plastics are tolerant, treated leather and canvas materials should work well.
Demko freereign, CS srk. Some lionsteels like the t6 have micarta enveloping the front side of the tang, leaving only the spine side exposed.
From all my cold weather experience, I'd be looking at all the stuff with big handles and FRN or similar sheaths. Leather is good, but the maintenance is a factor. I've not seen kydex in the cold, but I'd be hesitant. I'd be going for a bucket sheath with a strap retention, and kydex tends to be tension style which would be tough. That's where Falkniven shines.
I have an LT Wright next gen in 3v, which I would trust in cold weather, (even through its a small grip, leather sheath) but that's my biases for what I like and my experience level, (I live in the subtropics now, but grew up where snot freezes) So I'd think something like his genesis would also be very good, if that style appealed.
Other options would be the knives that Varusteleka are doing , I've got no hands on time with them, but if they are making knives for Finish reservists, that suggests they think they know a thing or three.
All that said, if you have issue gear, and this is class one, run the issue gear, learn it limits and then decide what would work better for you. The cold impacts us all a bit differently and so learning what doesn't work is sometimes more valuable that learning what does, since ideally a safe training environment is the place to make mistakes and have things go wrong. I'm only saying that from the point of view of someone who's done a fair level of "adverse" environment training, all non-military, and a huge part of what I learned is with issued gear that didn't work for me in very specific ways. I wouldn't know those were problems if I'd just rolled in with gear I was comfortable with. I'm talking gear like PFDs and climbing harnesses, so not exactly low-consequence stuff. I'm glad I know those things now. But it's also fun to do training where you can trust the gear and learn technique, so use that as a guide I guess for if you buy your own kit.
