This update to the design was focused mostly around streamlining the Mk10 Mod1 updates into a sleeker package, but I also added some new features that I've been waiting a long time to able to add that I'm pretty exited about:
Type 2 titanium anodizing- Unlike type 3 titanium anodization that changes the light refraction properties of the surface to produce a variety of colors, type 2 anodization converts the outer micrometers of the titanium's surface into into a wear resistant coating with high lubricity. This process is commonly used in the aerospace industry to enhance the the mechanical properties and temperature resistance of the material, and in the medical industry to prevent wear and increase mobility of joint implants.
Precisely sharpened blades- Instead of belt sander sharpening the square edge of the 1095 steel blades as previously, they are now sander beveled at 17 degrees down to a 22 degree sharpened edge produced with precision knife sharpener.
Updated "guard" component- This is the component that partially covers a portion of the sharpened blade edge when the knife is folded. Rather than a guard that swings freely and can impede the function of the knife by being constrained into position upon opening/closing, the guard is now linked to the "arm' (a rotating component of the blade) so that if follows a set path into both positions.
Other features include 6-32 screws instead of 4-40 screws, a 1095 steel logo plate held in place by neodymium magnets, aesthetic geometry changes, and a length change to approximately 12.3 inches when opened.
Materials of components and hardware are identical to Mk10 Mod1, Which is a modified version of Mk10.
Mk10 Mod1 changes:
Mk10 design break down:
I wanted to make a knife with a high degree of modularity so that when a component is damaged it can easily be replaced.
www.bladeforums.com
More Mk11 pictures:
Mk11 open/close video:
https://youtube.com/shorts/Yb_ytPded1Q?feature=share
