Collection Sale | PM2's, Mongrel, Isotope, Ace Grand, Maverick, and ZT's
TenShun705
Feedback: +226 / =0 / -0
Howdy BF,
Still trying to slim down the collection. Only looking to sell to fund a project I’m working on. I’m open to reasonable offers via PM and email only. Some of the pictures might reflect poor lighting causing some of the images to have darker areas around the blade, but if I don’t call anything out, it’s just the lighting. I’m also happy to text you a video, just message/email me that request if desired.
Spyderco PM2 | Black S45VN | Camo G-10 | C81GPCMOBK2
CONDITION – VERY GOOD: has been used and sharpened. There is some discoloration on the finish of the blade. The scales look great with very minimal wear. Clip shows majority of wear. There’s a pin-sized dot on the spine near the thumb ramp that shows some of the coating missing. Centering slightly favors the presentation scale. Action it very good and it will drop shut if you depress the compression lock-bar without squeezing the handle too tightly, otherwise a slight shake will get it closed. I purchased this from a brick and mortar in FL at retail.
ASKING PRICE: WITHDRAWN
https://photos.app.goo.gl/V73xFe4BtZam55hm6
Vehement Mongrel
| Satin CPM 3V | Bronze Ti w/ Brushed “Bolster”
CONDITION – VERY GOOD: has been used and sharpened. I had a challenging time getting the clip-side of the blade near the ricasso to form a burr so I ended up raising the bevel a bit higher than the rest of the edge (see pic with red circle). Action is very smooth. Doesn’t drop-shut, but a shake or two will do the trick. Very solid lock-up without any blade-play. No discernible wear, not even on the clip. If it wasn’t for having been sharpened, you most likely wouldn’t be able to distinguish from a like-new one. These don’t pop up too often and I paid $539 ($495+tax) from DLT back in August of 2021.
ASKING PRICE: RELISTED
https://photos.app.goo.gl/DcAC9wbrV2mRnYYG9
Vero Isotope
| Hand-Rubbed Satin M390 | Integral Ti w/ Red End-Cut CF Inlay
CONDITION – EXCELLENT: has been carried a handful of times, but never used (may have tested the edge on paper) nor sharpened. Comes with Skiff bearings for which is currently installed – original ones will be included. Action is very fluid – snappier with the middle finger flick, but more subtle with the flipper. Centering is flawless and locks up solid without any blade-play. Only discernible wear may be on the pocket clip, but even then I’m not quite certain because of the finish overall on the Ti components. I paid $525 direct from Vero back in late July of 2021.
https://photos.app.goo.gl/XVfxQDgr47gh53Aj6
Giantmouse Franken-Ace Grand
| Blackwash Vanadis | OD Green Micarta
CONDITION – VERY GOOD: has been used and sharpened. I basically pulled the scales from a stock OD Green Ace Grand and used the blade, hardware, liners, and clip from the REC exclusive. Very well centered with a solid lock-up – no blade play whatsoever. Very good action with a two-shake close. There are some lighter shades on the blade finish from use, but the only other wear is on the clip. The scales have darkened from handling.
https://photos.app.goo.gl/9aS8CsyWiaojgu6w7
Tactile Turn Maverick
| Satin Magnacut | Milled Ti
CONDITION – LNIB: has been pocketed once around the house, but never carried outside. I’ve only tested the edge on paper and it’s quite sharp. Centering looks perfect. Action is very smooth with a drop-shut close. Lockup is very good, but if you muscle it, you may feel a bit of movement – not entirely uncommon with these types of locks, but certainly much more solid than most Benchmade Axis locks I’ve handled. I paid $358+ direct from maker and have only seen one other online retailer with these in stock.
https://photos.app.goo.gl/KzM3WWFm39Lh2met7
ZT 308
| CPM 20CV | Coyote Tan G-10
CONDITION – EXCELLENT: has been carried a couple of times and has cut paper. Still has factory edge. I’ve disassembled it to re-lube and replace the bearings with Skiffs, but have since sold the bearings so it's now running on stock ones. Action is quite smooth. Locks up solid without any blade-play. It will drop-shut close under its own weight with a slight nudge after you disengage the lock-bar. Perfectly centered to my eye. There are (2) highlighted areas on the spine that I circled with very tiny dings – came this way to me from another seller here on BF. Other than that, there is a bit of wear on the end of the pocket clip about the size of a small dot.
https://photos.app.goo.gl/KXyriz7BSdiC7DVj8
ZT 0562CF | CTS 204P | Carbon Fiber Front
CONDITION – GOOD/VERY GOOD: has been used, sharpened, and re-assembled. I’ve cleaned it out a couple of times since I got it in 2016. There are light surface scratches on the blade with one area near the spine (see pic with red circle) that has a very slight chip from my sharpening clamp. It had a semi-mirrored edge, but I recently sharpened it and have since then removed it. It is sharper now than when I received it. Action is very snappy and it locks up solid without any blade-play. Centering is near-perfect, possibly leaning a smidge to the clip side. It’s not drop-shut, but will shake close easily.
https://photos.app.goo.gl/roL7tXQmFzyH1FYSA
Spyderco Franken-PM2
| Satin Rex45 | Flytanium Lotus Ti
CONDITION – VERY GOOD: has been sharpened, used, and disassembled for the scale replacement. The blade is from the BHQ Copper exclusive, but those scales will not be included. Action is very good with a drop-shut close. Centering is near-perfect. Lockup is very good with a slight side-to-side wiggle, but you should be able to adjust that out by tightening the pivot. There’s a patina on both sides of the blade from food prep. No box or docs will be included, but I will package it very securely using bubble wrap. Scales alone were around $80.
ASKING PRICE: $180 F&F/Zelle --> SOLD to D dadofsix
https://photos.app.goo.gl/BeVUBHEzuqkJo6WN6
TERMS: First "I'll take it" followed by a PM or email (cchild107 at msn dot com) confirming payment will typically get it.
PRICING: references payment via PayPal or Zelle (no knife reference notes, please) and includes shipping (CONUS - no International at this time) via USPS Priority or First Class -- alternative shipping options available upon request (buyer responsible for additional charges so please indicate so in PM or email) -- discounted pricing for F&F/Zelle. Please ensure your PayPal address matched the one you provide me if paying via G&S. I will NOT accept payment through international PayPal accounts and will refund you immediately at your expense (you’ll incur the loss of the fees). Payment expected within a reasonable timeframe unless communicated on ahead of time. Will usually ship within 24 hours of cleared payment unless otherwise discussed beforehand.
All item(s) include original manufacturer packaging and contents unless specified otherwise.
Additional info and images available upon request.
***Please be advised that by posting or sending a private message/email with a commitment to purchase implies you're abiding to your state's laws regarding ownership of any item(s) on this sales post. Also, I ultimately reserve the right to sell to whomever I choose***
Not interested in TRADES currently as I’m trying to recoup funds for another purchase.
Thanks in advance for your time and consideration!
