Tom Militano said:I also have ATS34, 440C, and 416SS with green ends. I have some D2 and A2 with red ends. 1084 with a blue end. With all the technical info out there about various types of steel I've never figured out why the steel industry has never set guide lines as to color coding. I realize steel will vary from company to company, but they could at least put you in the ballpark with a standard coloring system.
DAMNENG said:Larry
According to the Heat Treaters Guide, normalize at 1650°F, austenize at 1600°F, Oil quench. Don't stop to scratch once you pull it out of the Kiln/forge, you have three to four seconds to drop the temp below 800°F or you cut across the P nose and end up with some pearlite mixed with you martensite. If done right you should get a HRC 60 as quenched. The table showed a temper at 400°F veilding a Brinell hardness of 550. I can't locate my cross reference but I believe this is about HRC of 57. I'll look for it tomorrow and shoot the info to you.
Jim A.
