Yep use the blade.
I have tried the spine of my infidu and it wouldn't work.
David that's a great idea. I really wanted to avoid using the blade, and I didn't want to carry a separate striker. So I'm gonna attempt to remove some coating from the butt and try to square it to 90 degrees. I'll try and post some pictures when I'm done.
It may seem like a good idea but just keep in mind that a sharp 90 degree angle can and will slice you pretty good given the opportunity. Many Busse's come with what looks every bit of 70 degrees inclusive at the tip and it definitely will slice you, another 20 degrees won't eliminate this possibility. A sharp 90 deg corner on a pommel is the last thing I would want to carry on my belt, but YMMV.
Grind a little of the butt of the knife.
The butts get warn from rubbing you any how
Striking a fire steel on the edge can and will ruin the edge, I have done it and it does.
Most important, if you use the butt of the knife it allows you to keep the knife sheathed and no edge exposed to possibly cut you.
Its not the blade edge dulling that is the concern, its the temperature of the sparks that is the concern. That kind of direct heat will destroy the temper of the steel in that small area. The steel becomes brittle and breaks off the edge easily. Takes quite a bit of sharpening to replace that edge.
But, its your property, you have every right to use it like you want to. But do heed the warnings given here, they are well intentioned.
My first fire steel many years ago came with a section of hack saw blade, it was perfect! The new styled strikers that come with Swedish Fire Steels dont throw near as aggressive a spark, and they take up more room. Hack saw blades are cheap and easy to find and always seem to break. Good striker fodder.
kjd, the heat generated is very localized and very intense, the thinness of the edge dissipates heat rapidly. Unfortunately repeated heat cycles like that are harmful in time. The edge will heat blue in time, that is when you know the damage is done.
