Combative Edge M1 and SR11 Wharncliffe
Feedback: +16 / =0 / -0
Combative Edge M1 - sold – Lightly Used – Slightly off-center but does not touch. Good Lock-Up. Blade has a few very faint lines you can only see at certain angles. CF Scale (also have the original brown scale) and Ti has no scratches. Clip has been Acid / Stonewashed and shows very little wear. No movement side to side but does have a little lock rock. Has been anodized Green with almost a wood grain appearance and matching Ti bead. Also has a Pete Gray Copper LBS. When I was disassembling it I realized the LBS screw had been stripped previously, fortunately with the clip design it sit directly over the LBS. I have never had the LBS move or fall off. I’m sure you could get a replacement screw I just haven’t done so yet. Also it isn’t the best flipper but will fly open with the thumbstud, either with your thumb or middle finger. Videos in link. http://imgur.com/a/i5ODG
Combative Edge SR11 with Wharncliffe Regrind - sold – When I got this it looked as though someone had tried to remove the coating with a dremel or something. I had the knife sandblasted and had the blade reground to a Wharncliffe. I then Acid / Stonewashed the blade. Knife hasn’t been used since the regrind. In the pictures you can see the blade still shows a few spots of the dremel handy work. Blade is slightly off-center but does not touch. Good Lock-Up. Ti has been anodized blue with bronze edges, has matching LBS, and a blue Ti bead. Clip has been Acid / Stonewashed and is missing 2 screws, can probably get replacements. Videos of action in link. http://imgur.com/a/bfhLI
All prices are shipped Con US. Paypal F&F or add 3.5%.
