Well that's pretty cool Rolf, I can't flip any of mine without wrist action, maybe because the weight? Very cool nonetheless.
I've actually been having a heck of a time with my new PSARK. When closing the blade, with the it being curved, the tip was being pushed VERY close to hitting the lock side liner. If I loosened the pivot, it WOULD hit. I tried loosening all the handle screws and pivot screw and placing a paper wedge between the lock side liner and the blade, then tightened everything up. My hope was that this would move the blade to be off center towards the non-locking side. No success. I even went as far as to try a slightly thicker brass washer on the locking side to give the blade some more clearance. This worked, but I wasn't happy having two uneven width washers. Finally, I decided to try to adjust the second detent. I reduced the bend by about 50%, placed the original washer back and tightened it all up again. By the way, I'm tightening starting with the handle screw farthest from the pivot and working towards the pivot, then tightening the pivot last. Well, with the adjusted second detent, this finally seemed to do the trick. I hope.
