Cliff Stamp said:
Cutting light metal is less demanding than batoning through less than ideal wood, by light metal I mean food containers. An edge at 10 degrees per side with a 20 degree non-visble micro-bevel can do this, even on production stainless steels. It has its uses in wilderness work, for example taking a pop can and cutting out a swivel to use fishing.
Pop cans are so thin you can almost cut through them with your teeth... if you don't mind cutting your lips a little. I use scissors to cut into them and it doesn't even dull them.
Thicker soft metal (like a real can, or sheet iron) will dull ANY blade, but it will never ruin the edge totally. I've cut into an old coffee can with an Opinel just last week. I had a hard time so I hammered the can on a bench and used a baton to cut through more easily. The Opinel came out dull, but not chipped, rolled or anything. And that was a reprofiled Opinel with a slightly convex moranish edge (no bevel, just one big, thin slightly convex shape, approx 2° per side at the steepest).
I tried doing the same thing with my Howler, and it performed very poorly. The thinker edge forced me to spread and bend the metal a lot more, which meant a lot more work. The edge on it was ALSO dull after cutting the metal, of course. NO blade will come out of that shaving sharp. Or else I trade my car for it in a heartbeat
What do I cut with a knife ?
Everything that I need to get cut. Mostly wood, but also bone, skin, hide, muscle, sinew, cartilage, metal, snow, ice, cloth, plastic, plants... Anything. I just know that, sometimes, I'll have to resharpen.
Hitting a rock while chopping happens, but I never dig with my blades. A stick does it. Given I need to do it, I know that it will mean resharpening, that's all.
The only thing that really sucks in a knife, IMHO, is a brittle blade. I'd pick a soft iron blade over an over-hardened one anytime.
Cheers,
David
