The high hollow grind on my vantage slices apples and other hard foods extremely well. Right on par with the thin full flat grind spydercos.
"Geometry, steel, and heat treat done right"
Buck.
Best 420HC in the business
Best S30V in the business.
The heat treat schedules developed for them by Paul Bos are tops.
For abrasive cutting, their geometry is also tops. Buck makes hunting knives, and EDC knives. If you want to baton, buy something else.
Their combination of heat treat and geometry on S30V will outcut knives in that alloy from Spyderco or Benchmade.
Buck Knives gets it right with their heat treat on their steels. DM
I'd have to strongly disagree, Beckers are more than capable of "slicing" with the benefit of being able to withstand hard use. Obviously not all models were designed for slicing, but can still easily accomplish it. Many people use the bk5, 15, and 16 as there kitchen knife.
Tops is another one that has excellent heat treat, and good blade geometry. For a less expensive option I've found the latest offerings from schrade to have a great heat treat and decent blade geometry.
Have you personally used them all to come to this conclusion? Or are you looking at pictures of them online and creating an uninformed bias based on appearance alone? Cause anyone who has actually used a bk5 or 15 will attest to how "slicey" they actually are. The blade geometry of each individual Becker works prefect for the intended task it was designed to do, but will also excel at other tasks just as well.While people may "use" the geometry for a kitchen knife, it is undeniable that it won't cut with the same efficiency as a thinner knife, let alone a proper kitchen knife. I can move a house with a car, but that doesn't mean that it is the most efficient tool for the job. I get the feeling that people who do "use" them for kitchen knives do so just because of the novelty of it.
I've been in the knife industry long enough to know how a knife will perform when compared to a knife that is properly designed for the task. My conclusions are not based on any uninformed bias on appearance alone. Are your conclusions based on blind loyalty to a brand?
Until you've physically used them everything you say isn't relevant and mere uniformed personal option. You have no data or experience to back up your claims. Until then thou I have nothing else to say to you on the matter, as you bring nothing to the argument of significance.
Blind loyalty to a brand? Lol that's funny. Yea I love my Beckers, but also love my tops, benchmade, and others as well. Beckers don't just have a mass following for sh!ts and giggles, everyone who actually USES them will attest to just how good they are.
Most of these are pretty subjective, or relative to the task they're supposed to do.
I will say that I do find that the Kabar/Becker HT and geometry is pretty good (for the 9 and 16 in particular. The 9 has a wider chord than the other models, and although its still thick stock, it slices better than the 10/7) for general use woods knifes. However, they make awful kitchen knives, and I've commented to that effect several times in the Becker subforum. While the 15 is better than most other Becker models (its thinner, and has a good belly and distal taper), its nothing like my Tojiro DP, or other "real" kitchen knives.
However, that's not a knock against the Becker, as they're just not designed as kitchen knives. And yes, I have, and use both the 9 and the 15, so I can say that.
I also agree on the Mora, Opinel, and Victorinox choices. So far all of the ones I've had have had good edges, and they keep them for as long as I'd expect them to (unlike the past few Gerbers I've used for instance). The Mora is great for its use as a wood carving knife (not great at slicing though, because of the grind that makes it good at wood carving), and the Opinel is my favorite fruit/food knife as it slices like nobodies business.
Otherwise, my ability to comment is a bit useless, as I don't own/haven't used most other brands (Spyderco, Benchmade, etc). The one Kershaw I own seems to have good HT though, if that's worth anything.
