Comparing different kukris
Lethal_current
Basic Member
Hello! I am very new here and just plummeted down the rabbit hole of kukris a couple weeks ago. So I have been looking into your different kukris and seeing everyones positive reviews on what they've picked. For me I'm interested in something sturdy and for outdoors work like gardening and camping, so my top options are the panawal, ek chirra, or msi. At the moment I am using a cheap cold steel kukri as a test and like the 13" length but it is much too thin for any serious batoning or splitting. My main question is what is so different about the ek chirra and panawal if i get them in the same configuration? My preference would be a 13" blade and full tang micarta scales. Because I see they have a similar spine thickness but there is more belly on the ek chirra if I were to guess? I'm a nerd when it comes to specs and having an informed decision so thank you for taking the time to read this and for anyone giving a response!
Have you considered the Pensioner or Fort William? MSI is probably the least interesting/optimised offering. Although at least it's a bit more refined than typical MSI's from other makers.
Personally I'm not so interested in full tang; rat tail is strong enough and has decent weight savings / weight distribution implications. If you're going to be batoning wood a lot and that's pushing you to full tang, maybe consider a hatchet? I've batonned some wood logs with my HSI and didn't have any concerns about damaging it. But it's not something I've done a LOT of, so ymmv.
I don't own panawal or ek chirra so I can only say, on paper the differences are 80g and $39 (for full tang). Shape of the blade and the single fuller of ek chirra would make it my pick of the two.. but I'd consider rat tail options first. If you really value something super indestructible then sure, why not.
I agree with HJA. If you'll be using it almost solely for batoning, a hatchet is more optimised for that task. If it has to be a Khukuri, have you considered Falo? While Pensioner and Fort Williams are powerful choppers, they have a taller bevel and will stick into the wood more than Ek chirra or MSI. In it's default raw finish, falo has better resistance against the elements, and if you go for the heavy duty grind, it should should have enough mass just behind the edge to help with splitting.
I have checked out both the Pensioner and falo which are both nice. I could come up with customizing the falo to have the bump in the handle others do or such but for me it's mainly something I know will last a lifetime as I still have many years ahead of me. I already have an axe and hatchet that do the jobs well at home which is why I want it more for the fun and functionality while backpacking. It bridges the gap of a machete and hatchet while being capable enough to do some woodworking a hatchet or machete would struggle with. It's not perfect but it's not the point. Having a full tang is for redundancy for if the scales ever do need repaired. I enjoy the quality of a well made tool which is why I'm very fond of kailash and seeing the work they do it's quite inspiring. So yeah it's basically a multitool for me around the yard digging for roots in mulch, chopping/splitting smaller kindling and limbs, sometimes carving and working with wood, food preparation, ect.
Glad to see a new person stumbling their way into the wonderful world of khukuris :)
I think the first thing to establish that in the grand scheme of knives pretty much any nepalese made khukuri is on the sturdier and tougher end of things and well suited to tasks like gardening and camping. From our lineup for example we only really have the salyani which we consider a little lightly built for these tasks and potentially the chitlange but in that case it is just the tip that is a concern. As a result, if you come into Khukuris and are specifically choosing the blades that are tougher and more heavily built, you might find that you end up with something that's significantly tougher and burlier that you need and you may lose out in speed, control, an exciting feeling when you're swinging it and also in cutting efficiency. I think this is a part of why the users previously in this thread have suggested that you look into rat tail blades, as many people consider these more than sturdy enough, and they are lighter and have a more lively and exciting balance with, at times, better chopping performance due to weight distribution :)
A khukri is very much capable of doing batoning, splitting, and generally replacing a hatchet in the kind of style that you're suggesting. However for a khukuri to match an axe these blades often have to be somewhat optimized for this task- it isn't going to happen by accident. Ensuring that the blade has a fair amount of weight, as well as a lightweight handle for a powerful chopping balance is a great way to go about this. This is why you may have seen the Fort William or Falo mentioned previously as these are both rat tang blades with some of our most powerful chopping weight distribution. Unfortunately though, the inclusion of both micarta handle material and full tang significantly hampers your ability to get this kind of powerful shopping balance as the handle can become quite heavy.
It's at this stage that we should take a step back and consider whether a full tang is something that is genuinely needed for your application. Full tangs are an awesome addition to many knives and in the world of fixed blades where they are primarily used for batoning and cutting and slicing, they are an almost immediate addition with no downsides because the dynamic balance of such a knife is not as important. This is because they are not swung around like an axe, a sword, or a hammer for example. On a rat tail tang blade, in our experience, this handle construction is strong enough for any kind of wood chopping and outdoors tasks and can easily be used to split and baton into wood. Rat tail failures on our blades are very uncommon- maybe more uncommon than full tang to be honest. This is not due to the rat tail construction being stronger but full tang customers more frequently doing much sillier things with their knives haha :)
The only things that a rat tail tang should not do and which necessitate the addition of a full tang are if you are wanting to strike the top of the handle while you are batoning, if you need to lever the handle out of the wood while you are batoning, and if you are needing to pry or dig from the handle with a kukri. You can still pry with a rat tail tang just fine, however, you just need to hold it at the ricasso and pry almost in a pinch grip rather than using the full length of the handle. This isolates the tang shoulders and cho removes the risk of breaking at these locations. Depending on the size of the prying or batoning task that you will realistically need to do, it's very possible that the addition of a full tang is not required for these tasks. A secondary note is that if you require a full tang for these heavier prying, levering, and batoning tasks, then it's probably not a bad idea in our estimate to opt for the cho to be removed also. In our experience over the years, the only full tang blade failures we have seen are in that kind of work (particularly prying and levering) and they have occurred at the cho itself.
The panawal is most similar to an MSI in terms of blade pattern and shape. This is a more modern (1990's) style of kukri that became ubiquitous due to the military connection and being particularly economical to manufacture. It is slightly narrower and significantly straighter than many older kukris. Some advantages of this kind of blade style is that it has a stout and aggressive look, is reasonably narrow, meaning that for a given spine thickness it is often lighter, and that the straightness can make some tasks a little more intuitive. For example, the tip is closer to being in line with the handle, which means it is easier to thrust with. The belly is also not as drastically curved, which at times can make it easier to place your strikes when chopping. The ek chirra, in contrast, has a slightly more traditional kukri shape with quite a narrow waist and a broader belly. On many blades this shape is associated with higher chopping power, as it can put more beef towards the front of the blade. It is also often associated with better cutting efficiency, as you can use a higher or steeper bevel which will form a thinner wedge that slides into wood more easily. With this said though, our ek chirra is not a repesentative example of this broader bellied style because it does not form a wedge all the way down to the edge as you might see on our Fort William MK1, for example. Instead, it has a distinct edge bevel with a hollowed out portion in the blade. This gives it particularly unusual handling traits for such a broad-bellied blade. It makes it quite lightweight with a faster feel in hand and it also gives it a lot of rigidity and toughness in the primary grind at the expense of cutting efficiency. This is because this very distinct bevel is quite thick and, as a result, it does not sink as deeply into wood as other blades mentioned in this thread, such as the Fort William MK1, Mutiny, or Pensioner, which all have a lean and blended bevel. This begs the question, what is the Angkhola Ek Chirra good for? The answer to that is that it's a cool looking, tough all-rounder. It has an imposing blade profile with a moderate balance that is more manageable than you might expect. It is quite tough and it features fullering, which people appreciate on an aesthetic level not just for looking cool but also for showing the craft involved with the creation of the blade. This is something that is just as important to people today as it was 100 or 150 years ago in Nepal :)
Have a think about whether the full tang or micarta is locked in as the first step :)
If you can provide a breakdown of your needs eg 60% chopping, 20% machete style brush clearing 15% carving and camp work 5% self defence then I can make a tailored recommendation :)
First off very well done, your way of explaining the intricacies provokes a confidence you only see in people with so much passion. I have looked at a lot of reviews for your kukris on youtube and this is much more helpful. You have convinced me the full tang might not be as important as it may seem for someone who does do a good bit of batoning as im smart enough to not pry at the most vulnerable part of a tool. That being said you took the words out of my mouth about the cho it would make sense to remove it in place of a finger choil which would also give it better dexterity for finer carving and notching. So how an axe can get stuck in wood you're splitting you can remedy that with the geometry or the blade by having a convex edge so you won't be in a situation to have to pry as much.
So I guess for me it would be a good mix between felling and splitting wood so 50% there, I want it to be a bit nimble for finer tasks like notching which a choil would help with so 25%, and the other 25% can go to general out the box tasks that come with harvesting and camping/bushcraft.
Again, really appreciating the feedback you guys have!!
Hey there- thanks for the utility breakdown :)
Yes for the most part you can get away without a full tang just fine. However there are certain valid applications that are particularly pry heavy where it's non negotiable for sure. For me when I am in these situations I tend to grab a big full tang straight blade instead as the shape is better suited for prying also. Khukuris can still very much "bind" in wood though the types of grinds they have tend to limit this compared to other knives. It can definitely occur in splitting though and its good to keep tang shoulder strength in mind when removing it in these situations- I tend to hammer the tip out then wiggle the handle to free it up.
I think considering defence and machete style brush clearing isn't a priority then we can feel confident in the move to a shorter and heavier blade. I think the addition of a finger choil seals this- it means that you can move further forward to tame the more powerful chopping POB we're likely going for. Keep in mind that you can always pinch grip the blade for finer tip work and slicing control if needed also. A shorter overall length will enhance the greater level of control that you get from this finger choil as you'll be "choking up" on a higher percentage of the blade length.
I think for you I'd probably go a 12" falo with an added finger choil and a snug fitting handle 9rather than sizing up). You can do a micarta wrap handle if you'd like and the blade should handle this weight distribution no worries or you can go with rosewood for something more traditional. If you go micarta we can do a captive tang to trim even more handle weight from the rear of the blade (lowe weight, better chopping pob, helps offset weight of micarta) If you're not into the forged finish we can do satin for you which would look like this 10" version. If you're interested in a more modern design send me a dm- we have something currently unreleased that is likely a good match for your needs :)
The falo does present the most utilitarian option especially for the price. It might seem dumb but its a little too basic for me. The gradual curve isnt something I'd like compared to your other kukris which sounds nitpicky since the falo would be good at everything I'd want. I'll keep the suggestion in mind though as I think more about it how would you like me to reach out to you I cant figure out how to dm here?
It's definitely a plain looking knife but it's far from simple. The handle design and flared bolster are very considered and I consider it probably our most comfortable handle. If you're looking for more ornamentation, finish changes, fullering etc these can all be added as semi custom requests on top of the base falo blade and handle shape.
You can DM me by clicking my profile to get to my profile page then below the profile picture you can find follow, ignore and send direct message.
I'm happy to answer questions in here especially as it might be helpful to others :) Just have to be a bit sneaky about this currently unreleased option
"Unreleased option"....this is interesting....
I like your thinking. And this sounds like its gonna be your first Kukri? So somthing with a bit more of a classic style/flair would be sweet. You have made a sound choice looking at Kailash.(most of us start our kukri journeys with awful "kukri house" types) And as you can see from the response and interest that Kailash show in their products and providing advice etc they are a top operation. They have a ton of knowledge and passion for what they do. I genuinely expect that this will be the first of many orders that you place with them pal. My advice would be to go for a classic, traditional model. Ive been collecting/using and reseaching Kukri's for years and id 100% recomend the Pensioner with a micarta handle for that added toughness. Its a fantastic all rounder and looks beautiful. Its a classy kukri with a classic heritage and its a tough bit of kit (even with the performance grind) Mix that with the high quality materials, craftmanship and the modern heat treat and BOOM! Simply a great kukri. Very suited for the tasks you mentioned and one that IMHO really highlights what Kailash does best. (Innovating on heritage and blending the classic with the modern). You could happily be "one and done" with that model. Safe in the knowledge that you own an exceptional kukri. But more than likely its going to be your first of many. (I dont think i know anyone who has just one kukri) So that is my two cents. To be honest, you cant go far wrong with Kailash. I just hope whatever you pick you will be thrilled pal. Exciting times.
No hatchet, a beast chopper is a great way to go. Chopping down trees and firewood with a kukri is awesome, just make aure the handle is a good grip.
