Comparing Griptilian (tanto) to PM2 (Blurple)
This really isn't a valid comparison except that I'm trying to decide which one rides shotgun to my Spyderco Yojimbo 2. I realize the Grip drop point would make more sense but I chose the tanto because I want a sturdy EDC EDT (Every Day Task) type of blade. The Yojimbo 2 is tough, strong and laser sharp, but I want to keep the tip as sharp and pristine as possible (which is probably ridiculous because I use all my knives and have no trouble maintaining or sharpening them).
But for the sake of discussion, I'm weighing the pros and cons of the Griptilian 553 vs. the PM2 for my grunt tasks. In this case the Griptilian is in 154CM (which I love), and the PM2 in S110V (which I'm learning to love). I have confidence in both steels for the type of cutting tasks I do daily- mail, opening cardboard boxes, plastic packages, dog food can tops, etc... But my reason for wanting to explore a lesser expensive, more robust blade tip (Grip) is simply for durability.
Considering the roughly $20 price difference ($50 difference for the S110V) between the Griptilian and PM2, my general observations follow:
I like how both knives feel and handle. The PM2 feels a little more refined, which could just be because I'm used to it (I've carried a Military for years). The Griptilian is nice, if only a little "cheaper" feeling in the hand, due to the handles. But on its own it feels sturdy and comfortable- solid with good grip purchase and balance.
The Spyderco action definitely has the edge in smooth operation and the compression lock is outstanding. The Griptilian feels solid, if not as smooth as the PM2 and the Axis lock feels secure.
Both blades are extremely sharp. The 154CM is likely easier to maintain, and I'd feel less hesitate using the tanto tip of the Benchmade for things like popping dog food aluminum tops with that gentle rotating prying motion.
Thumb stud vs. Spydie hole? I like 'em both. Probably faster with the Spydie hole strong hand, slightly more coordinated with the thumb stud off hand. Go figure.
So overall, both knives are perfectly suited to handle what I use my EDC EDT knives for. If I need something for heavier duty work I go to one of my Moras or the tools on my Swiss Champ. Oddly enough, perhaps the over-riding factor will be the clip. I can carry the PM2 any which way I want- strong side, off-side, tip up, tip down. The Griptilian allows for only right or left side carry, tip up. It's a mild "disadvantage," but perhaps just enough.
For anyone who has tortured themselves by reading through this meandering comparison, I'll save you the time and respond for you:
"JUST KEEP BOTH!" Which I may do.
I know, I know. Both are awesome. I just don't want any "drawer queens," so I want to narrow it down to just the one for opposite side carry to my Yojimbo 2.
In looking at the blade construction between the two knives (steel notwithstanding) they really aren't that different in terms of thickness. The geometry of the Griptilian tanto is of course different, but I'd guess the PM2 can handle a lot more grunt work than I've put it through.
So maybe the answer is to carry both, and put Yojimbo 2 in the back pocket! That leaves an entire other pocket for something else!
Until then.... thanks for reading!
Since you're already carrying a knife with a spyderhole opening, I'd suggest going for the Grip just to mix up the lock and opening system.
I'm not sure why you think a tanto blade is more sturdy and applicable to EDT, I tend to feel the opposite about both the (Grip) tanto and the (Yoji) wharnie. They may be better for puncturing or from a self defense standpoint, but I've never found them better for EDC tasks. Opening cans is best suited for a can opener...or a fixed 1095 blade...
If I had your choices and budget, as well as a commitment to carry the Yoji, I'd get a drop point or sheepsfoot Grip in 20CV/G10 and work the two together.
Thanks for reading my vacillating narrative! Great suggestion on the mix and match of the opening and lock systems.
By opening cans, I mean popping the aluminum tabs- I use can openers for the cans without those tabs. Or I can resort to my SAK can opener.
I don't mean to broadly proclaim tantos are better for EDC tasks, but only rather my type of EDC tasks. I think most people would agree with you that a drop point is far more versatile in general. I just find myself liking the tip of a tanto for the various types of applications I come across on a daily basis. And since I usually also have a drop point with me, I like the diversity of blade shape.
As far as sturdiness, I think "pound for pound," or at least geometry for geometry, a tanto tip is going to be stronger than a similarly sized (thickness) drop point tip. That said, I would like to compare the Griptilian in drop point to my tanto because it doesn't look like that much of a difference.
I will say the Griptilian tanto is unlike any I've ever carried. I liken it to a "shark tip" tanto- like the profile of a tiger or bull shark- it has a shallow, gradual angle as compared to some of the steeper angles I see on many tantos (think Kizer ki4436m, a knife I regret letting go). I have a suspicion that more people would gravitate to a tanto if they handled the Griptilian tanto. Not more than drop points, but I bet more "non-tanto" folks would find a niche for this one.
I almost pulled the trigger on the Sheepsfoot Grip, and given my predilection for S30V, I'd be real curious to try out 20CV.
