- Dec 11, 1999
I'm pretty weak on info on compass "dip' caused by magnetic inclination. I'm in the process of research and learning now but I do know that all hand held compasses are affected by it and have to be calibrated for it depending on where you're at. You are correct in that latitude is the determing facter here. There's 5 zones compasses are calibrated or 'weighted' for and commonly here in the states compasses will be MN or Magetic North. Sometimes they mark the underneath side of the compass vial. There are also 'global' compasses out which work anywhere.
This said it doesn't mean a compass made for here won't work in South America. It does mean however that accuracy will be affected depending on how far you go from where it was designed to be used. I've got one that's set up for MS or Magnetic South and it works fine here but if you look closely you can see the needle slightly dipping from a horizontal plane. Accuracy is slightly affected because the needle is designed to turn in a level plane on it's bearing mount.
I'll post up the reveiw site when I get through all the field test later in the year. There should be a lot of good info and I promise some myth-busting info that will surprise a lot of people.
Mike
