The ICCT is in the middle of a change to a non-profit organization. It will be governed by a board of directors rather than the business plan it originated under. In the near future there should be more competitions with lower entry fees. I think the web site and name will remain unchanged for a while as well as competition rules.
www.cuttingcompetition.com
If anyone has questions you can send them to me, if I cant help I will forward you to someone that can. While I am no longer involved in an official administrative capacity I am still involved as an advisor.
danielwinkler@bellsouth.net
flatgrinder,
Most of the current successful cutters are using full tang knives without a cross guard. The lanyard will stop your hand from slipping forward especially if you use the front safety lanyard system.
A good starting point on edge thickness is about .020 but you need to test this with the steel and heat-treating you use. Thinner is sharper but to thin wont hold up.
M4 is the best stock removal steel I have seen yet. Get it from Crucible.
Most cutters I have seen use a polished edge but this is an area of controversy. Testing again is your best bet.
Go to the ICCT web site and check directly with Gayle Bradley and Warren Osborne about grind angles and heat-treating M4.
deker,
The profile of the knife is important because some cuts work better with a flat cutting edge while others a more convex profile. Concave will cause problems with a lot of cuts. Most cutters are using a blade design with a slight "belly". I don't know exactly what you are referring to with primary, secondary and bevel.
1lb 4oz to 1lb 8oz is what most I have weighed fall between. I personally go a little to the heavy side. Warren Osborne who is a great cutter, a little to the lighter. Testing different weights will help you develop what works best for you.
The best handle material so far seems to be recycled rubber. "Horse Stall Mats" from Tractor Supply. It absorbs shock and has good grip either wet or dry.
A lanyard is mandatory and a forward style is safer for the cutter and adds to your grip if used properly. Hidden tang designs must use a rear lanyard.
Longstrider,
During this transition of ownership a lot of stuff is not getting done. You can e-mail Warren Osborne or me directly and get answers to your questions.
Daniel
