Is the cutting competition going to be similar to what they do here? Hard dowels, hanging ropes, delicate cutting, chopping 2x4's, etc?We have over here a fledgling BladesportUK organisation which is affiliated to the US Bladesport. I am thinking of giving this a go and have been looking at what knives I have which I could use....at least initially.
The rules are simple...no more than a 10 inch blade...2 inches wide...and the knife needs to be 15 inches over all.
So the choices really boil down to the Basic 9 or a FSH...with a FSH how thin have people taken down their edges to? By this I mean the angle inclusive. The steel should be at around 56-58 Rc so any experience on this side of things would be welcome as well. I normally go for around 20 degrees either side or 40 degrees inclusive on an edge...basically working off what Spyderco suggest is an optimum angle for mixed use and what they use on their Sharpmaker. What I find a bit staggering is that the competition knives are...if the figures are correct...progressing down from a 3/8th spine to 16-17 thou at the edge on thickness of blade and being convexed. Using trig maths this gives a 10-11 degree "inclusive" edge...which allowing for things like scalpels being sharpened for a 17 degree inclusive edge...makes you aware how far off the pace you are with a 40 degree inclusive edge.
But I don't want to ruin my knife...so how acute would it be sensible to take a sharpening angle to? I am thinking 36 degrees inclusive would be about as far as you could sensibly go? Again....anyone with any experience on this...please chime in.:thumbup:
Yes I must admit I cannot argue with the geometry point....and the only thing I cannot easily fathom is how they are getting a 10 degree knife to work like that...as I said above...scalpels are usually ground to 17 degrees inclusive...so it is quite eye opening that some have an edge at 10 degrees...those squared off cleaver shaped comp knives must be like a straight razor on steroids??
What suprises me is the thinness...if you consider that the Japanese were working on swords for nearly 1000 years...with hamaguru edges able to slice silk floating down over them...and none of those edges were anything like 10 degrees....albeit this was forged steel...not powdered metalurgy which they have today...it does make you wonder whether the 10 degree edge is actually the best...but allowing for physics and dynamics whereby the least resistance to a cut the better... I have to accept a 10 degree edge must be the best option.
Thanks Jerry! Did you find your comp knife?
As you know, I'm sniffing around for a Busse chopper. :thumbup:
If so, then I don't think INFI would be the way to go. The knives used by most of the competitors are ground really thin, I think it was calculated less than 10 deg. A while back, there was a poster who showed a Busse that was thinned out to 20 deg (there was some heated discussion on that), and Jerry chimed in and stated very emphatically that 20 deg was WAY too thin for INFI. I'm sure I could find that thread.
Based on that, you'll be outchopped hands down. A thick edge such as the asymmetrical one won't be able to compete with a thin one, just a matter of geometry. Some of the videos show competitors chopping through 2x4's in 6 strokes.
Jerry's tests, IIRC, are cutting rope for several thousand cuts and showing that there is still an edge, which is much different than the competitions that are done here. Yours may be different.
PS - Edited. The angle of the other knife was 20 deg.
