Finally finished my grinder a few weeks ago and got started attempting to make knives. This is actually number five, but the first four didnt make it past bevel grinding. We wont talk about those. Anyway here it is.
Its mild steel so unsuitable as a tool. I wanted to practice before I spent money on steel. This was a piece of angle iron. Dont make fun of my birdy frames. =) The handle is some pine that was laying around. I have some g10 but I didn't want to use it on this since the knife cant be used. I don't think I'll use wood again. It wanted to seperate at the butt of the tang as you'll see. Also it was hard to polish the pins without the mothers mag discoloring the wood.[img=http://s30.postimg.org/x0o4su3il/IMAG0496_BURST005.jpg] The *cringe* spine. This pattern I tried didnt work out. Its not very repeatable. I use a dremel. I use the rubber sanding drums, put double sided carpet tape on them, and attach my own sandpaper. Sanded to 2k this way. When I epoxied thw handles on it squeezed out into the pattern. Couldnt wipe it out so i thought I would experiment and fill it and sand it down. The effect was less then spectacular here but I feel like the process has potential. Next time I'll pigment the epoxy. And use a different handle material so it doesn't smear into the wood when I sand it. [img=http://s12.postimg.org/7tl534ibd/IMAG0497_BURST012_1_1.jpg] heres the underside. I like this simple pattern much better. It's quick too. I know the handle finish is rough on places.. I didn't go the extra mile because it's mild steel. I'm very particular though and the next one will show much more attention to detail. Mainly this was to get practice grinding bevels. Had to take it to a full flat grind because I couldn't get the line at the top of the bevel straight. I built a jig and thats helping. Here's a a pic of it. I think I'll make my tool rest tip like I've read about on here so that i don't have to take the knife out and switch it end for end.[img=http://s13.postimg.org/dj4gmd71v/IMAG0462.jpg]
Also I had only a 36 grit belt and an 80 grit belt. Had to file out the 80 grit scratches before I could even start sanding. Let me tell you its gonna help me to appreciate finer grit belts when I get some.
Heres a pic that shows the profile better. I know that front pin is all kinds of wonky. Needs to be back further and higher. I changed the handle shape after the holes were drilled and learned why you don't do that. I like the shape though. I think I had a kukri mind a little. My theory is the belly is better presented for cutting with the blade tipped down like that.
