- Jan 31, 2013
We used the materials we had at hand to see if the concept was feasible. Also keep in mind that 440c was not used the first time around, it was some stainless steel we had laying around, we aren't even sure what type it is. We plan to use the 440c in a later attempt. We usually have the clamping down and stuff doesn't move like the previous two attempts, but it just didn't go right this time. 440c as much as we understand is the standard for a lot of commercial knife making (if i'm wrong, PLEASE correct me). What would you suggest be a better core? Also what do you mean by a carbon core? Did you mean the carbon we are using on either sides of the steel? Or did you mean steel with higher carbon content? Those carbon pieces are meant to take up some thickness of the blade to make the entirety of the blade lightweight, and to give the thin piece of steel in the middle strength at the same time. Also if were to make the entire blade of carbon fiber, my father and I would be in a bit over our heads, we don't know enough about carbon to make such an attempt.
