- Oct 16, 2010
Gentlemen:
For your consideration is this Vest Bowie in CPM-154CM/Raffir Composite. The hidden tang extends 3/4 of the way into the handle and is set with a 1/16" stainless pin and G/flex marine grade epoxy. The black handle has brass and bronze film embedded in the composite substrate - it's called the Noble pattern. The solder joint on the double guard is perfectly executed with no pinholes. The flat ground blade has a rounded spine and distal taper. Heirloom fit on the handle where it meets the double guard. Superb fit and finish. Right hand/cross draw horizontal sheath. I hope you like it! The first "I'll take it," PM, or email gets it. $630 delivered CONUS. Paypal preferred to tsteingass@yahoo.com Thanks for viewing and all comments are welcome.
V/R,
TK
.195" CPM-154CM stock
HT to Rc 60-61
9 1/2" OAL
5" Flat ground blade - mirror finish
Rounded spine - distal taper
Raffir black composite handle
Brass soldered double guard
RH horizontal carry sheath
V/R,
TK
HT to Rc 60-61
9 1/2" OAL
