Knifenut, I was simply trying to use examples that you would get. Guess not.
Yes, there is a balance of polish to micro-serrations. Love to see you polish that edge in the field. Flint knapped knives are ancient. Nice balance of serration with polished on those.
You will never see a polished edge at a rope cutting competition.
Theory vs practical application is what is happening here.
I'm through. Take care.
You're still missing the point, which is this:
What is occurring on the edge and what is occurring near the edge are not the same. Honing by definition means straightening the edge, not removing microserrations on the side near the edge.
I agree that you generally want some abrasiveness
near the edge to remove material. How much depends on the interaction of material and the steel, but that's off topic.
At the edge, however, what you want is to have the steel as thin as possible because a knife is foremost a wedge. If the material is weak and thin (like paper), then all you need is to wedge it apart. If the material is thick (like wood), you want to get the edge in and let the abrasiveness of the sides do the work. There is exponentially more surface area in just a fraction of an inch of the bottom of the blade than there is on the edge. Serrations are not a counterexample to this line of reasoning. Serrations do not misalign the edge so as to provide those gaps. The edge along each serration is still aligned, only it changes the
side of the blade in two ways, both of which cause more material to be removed: it provides varying friction against the material (more abrasiveness), and it adds surface area.
You may say, "Well having those gaps in the edge doesn't hurt. It doesn't make the edge work less like a wedge," and that's true. What isn't true is that it cut for longer. There are two problems with that. First, an aligned blade becomes misaligned as it works, so you're starting from a farther position from dull. That's like saying a 2005 Ford F150 with 50,000 miles on it will last longer than a 2005 Ford F150 with 10,000 miles. Second, to generalize, there are two directions of force put on a knife when cutting, horizontal (along the edge) and vertical. Vertical force presses inward towards the blade, which has more mass than the edge itself and thus provides more support. That vertical force will cause it to bend to one side (to become misaligned) or chip from edge upward, as I'm sure you've seen on knives. Horizontal force is the transfer along the edge as you're moving the knife across material. Using your assumption that it cuts more material, it does that because more material is hitting the start of those gaps, which puts additional horizontal force right at those gaps on the edge, where its only support is the rest of the edge until the next gap.
