Compression lock... is it the same as a liner lock?
minimize
I searched the forum and haven't come up with too much specific to the topic (perhaps my search skill is lacking). Some say it is super strong, and others say its just a liner lock. Any thoughts are appreciated! Thanks.
It is but the fact that it is in the rear makes it safer. You never have to enter the blades path. Trust me its a lot more versatile and easier to open and close
I just bought my first knife with a liner lock a few weeks ago and I really like it. I'd say it's sort of like a liner lock that's in backwards.
It seems very strong but I haven't really stressed it too much. It's easy to close one-handed.
3 redundant answers is too funny. Dan's post says it all.
For the sake of not having 2 identical posts, I'll let Random Dan have this one ;)
No, it isn't a liner lock. What it does is wedge the liner in between the blade tang and the stop pin, which transfers any folding pressure directly to the stop pin. This pic should help (from Google images).
The compression lock is much stronger. In order for it to fail, you would have to crush (or compress) the piece of "liner" locking the blade in place and that is not going to be easy.
Interesting! Thank you both! This correlates to greater lock strength I would safely presume? I am excited for my Yojimbo 2 to get here, even more so now!
Beat me to it lol. It is one of the closest things to creating fixed blade strength in a folder. This is all my opinion but it is based off physics so... Yea
Damn! That is one serious endorsement! Thanks again!
For me the Compression Lock is the next best thing after the Tri-Ad, at least out of lock mechanisms I've owned and tried. With larger, beefed-up dimensions for the folder with a Compression Lock they would probably be neck in neck. Without emergency abuse or stupidity abuse the dimensions as is are more than strong enough.
Here is a thread I started to discuss linerlocks about 3 months ago. http://www.bladeforums.com/forums/showthread.php/898067-Linerlocks-Which-ones-you-trust-or-don-t-trust?highlight=linerlock Even some of the ones advertised as tactical, tough, etc. are not very good and do not pass spinewhacks and other simple tests without disengaging. If the $1 folders at Walmart pass any test that a 5 ounce $120 linerlock tactical folder will not - it is a problem.
Here are a few posts for you regarding steel vs Ti in locks and a few other things in a recent discussion on Spyderco forums.
it is just for reading a bit.
CRK actually heat treats the lock face. Strider, Hinderer I know of uses a carbidizer (spelling?).
Here is a post I did recently
"There are a few things I want to cover, based on my talking with custom makers and reading Bob Terzuola's book: The Tactical Folding Knife (hereafter BT), where he explains in detail the aspects of a good liner lock and the same principles are applied to framelocks.
Three points of contact:
1. Stop pin
2. Pivot pin
3. Interface between blade and spring (ie, lockface/lock engagement area hereafter referred to LF) Spring is also the liner lock, framelock.
This forms a triangle.
Now, the LF is the area lets focus on first.
BT. refers to the angle of the lock face to be between 7.5 and 8.5 degrees. Les then 5 degrees and the spring will jam. More then 10 degrees and the spring will start slipping off the LF.
Now the start of a radius lock face, the maximum therefore cannot exceed 10 degrees or else the lock will start slipping when the lock wears to that point. As mentioned as lock roll in the video when referring to the Strider.
Now.
Do not thing the angle plays the only role in the lock slipping. The finished LF can have a rough spot, not be polished enough, the spring's interface between the LF can also play a role.
Let us examine this from the Emerson website.
http://www.emersonknives.com/ekKnifeAnatomy.php
If the LF connected to the spring more in the middle or at the top of the spring where the detent is on most (point nr 3 closer to the pivot pin nr 2) then you would experience blade roll. This is when you have vertical type play but what happens is the blade actually rolls on the spring because the spring connects in the wrong place with the LF.
The picture shows the extremes of the different designs, you can have a lock that engages more then the bottom 0.90-.125" of the spring. Chris Reeve has proven this, but, you can also have a knife that engages only on that bottom 0.90" (point of contact in the picture)
Not every lock is the same. The basic ingredients are the same, but the final application is what the maker chooses. This can be seen even with Spyderco difference between the Military and the Gayle Bradly.
Now that is just the geometry of the lock.
The spring itself if it is Titanium can be heat treated or carbonized. Strider and Hinderer do the latter. This helps tremendously with wear on titanium and if done right will last you a life time. CRK and a few custom makers that I have do Heat Treating of the lock. Wear is about nun and equal to (if) steel was used.
HOWEVER. Titanium is NOT PERFECT and it can have flaws in it when received from the supplier. EVEN aerospace titanium (grade 5 titanium). These flaws only become apparent when it is used and is sometimes not even noticeable until it begins to form a problem. This is where a good warranty comes into play.
Steel used as a liner is not always the answer as well. Different steel interfaces can result in slipping. Steel on steel requires a lot of research to find what can be used and heat treated as a spring and still provide excellent wear resistance and safety.
Finally, lockup percentage is a strange thing and depends on the final user. I prefer later lockup as it usually means less chance of slipping off the LF.
I hope this helped you in some way."
At the end, if you either use Ti or Steel, the LF geometry is key.
I have Ti lock custom that I have flicked vigorously, the maker asked me to test the lock face.
Here is a video towards the end.
http://www.youtube.com/watch?v=YgNHm...1&feature=plcp
Start watching from 2.27 minutes.
BT also writes in his book there is no significance between steel and Ti if done right. A Sebenza will wear for a while and then stop. Most quality locks do this. Chris Reeve also wants a later lockup as he feels it provides a safer lock and less chance of slipping. I tend to agree. Besides. If any quality product wears out so fast, they should cover it under warrenty.
I have seen a 18 year old Sebenza. No issues. I have a Military with the steel insert. No issues. Both locks apply different end results, but the basics are the same resulting in great locks that can last you a live time.
BT also feels that the strength to weight ratio of Titanium is excellent compared to steel.
End
Not really. The routing that is done is to make the disengagement for the user more comfortable. STR has made Ti framelocks without any cutouts (routing) because the user wanted it only to have it returned later on because the user complained it was to difficult to disengage.
The cutouts (routing) also provide a "safe burn" for those "accidental moments" when the lock does fail due to excessive force on the blade.
A Emerson HD-7 showed this perfectly.
http://strsbackyardknifeworks.blogsp...dc-folder.html
In short
"Contrary to how many readers may feel about that picture above. That my friends is a design that deserves praise for defeating the way it was engineered to go. That HD7 above did its job and so did the designer/maker of the knife. I doubt any sutures or ER trips costing great amounts of money were needed with that defeat. We should all pray to be so lucky should we be the on the unfortunate end of a defeat ourselves one day."
The cutouts are the weakest link in a Framelock IMO.
I have been surprised by some framelocks. A kershaw vapor that I had would disengage with some force on the spine when not held in hand. When I gripped it the lock did not move as ones fingers actually force the lock in.
End
Dwayne
Emerson knives start live out so early because it is the Mr. Emersons personal choice for his locks. I know of custom makers that also do this.
However, in my experience it is Ti liner locks such as Emerson knives (and there are many others that also do this) that are not heat treated or carbodized lock faces of the springs that tend to wear much faster. In these locks the geometry of the lock has to be as close to perfect as one can get.
Chris Reeve.....well this is interesting because he is credited as the father of the "framelock" or R.I.L.
The reason why his knives do not really have a break in period, or if it has it is very little is one thing: Tolerance.
CRK also does what I feel is good practice in that they adopt the blade to the spring, not the spring to the blade. In other words, when they fit a blade to a lock, they have multiple handles that are pre-assembled, checking in which handle the blade fits best and then if required they grind the blade LF area to mach the spring. They never fiddle with the spring or springs LF area after it has been heat treated and bead blasted to mach the blade. This is good practice IMO and great makers do this.
The only real advantage steel has over Ti is not in its wear resistance, but IMO in its impact resistance if one wants to beat the out of the spyderco or other knife.
(I wanted to ad that my knowledge is not perfect and if any maker wants to correct me I am willing to learn, I am just sharing what I have learned from makers and books)
End
IMO the compression lock applies many of the features in liner and framelocks in a new package that illeminates many of the conventional draw backs. The compression lock is one of the few locks that even with blade play unless the lock is slipping of the engagement area (unlikely) will not fail.
Comp lock looks like an upside down liner lock at first glance, but the physics of how the force is applied are completely different. Covered in much more detail above.
